Correct Tire Size for 16x7 & 16x8
I've searched the forums but I cannot find a good thread that states the standard tire sizes for my new wheels.
I have a '74 narrow body mid-year. I have just purchased 951 Fuchs 16x7 & 16x8 wheels. By the way (they are being delivered from Fuchs Restoration Service tomorrow ).
What tire sizes are recommended for these wheels. I'm assuming that for the front, the turbos had 16x7 so I probably should go with that size tire. For the rear, I won't go any wider than a 225 but I'm not sure if these should be 50's or 45's.
Any advice would be appreciated. Especially anyone with experience with 951 Fuchs on a mid-year.
Thanks,
Old 12-27-2016, 06:04 PM
205/55-16 & 225/50-16.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-27-2016, 06:06 PM
Thanks Steve!
Old 12-27-2016, 06:45 PM
^^This. You could optionally use 245/45-16 on the rear (Bridgestone RE11s work).
Old 12-27-2016, 06:46 PM
Rescuer of old cars
Arne2's Avatar
probably not on the OPs narrow body mid-year.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 12-27-2016, 07:00 PM
Registered Minimalist
75 911s's Avatar
Did you see this thread? 16x8 Fuchs on a narrow-bodied Targa
How did you get them refinished?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 12-27-2016, 08:23 PM
Did you get the memo?
onewhippedpuppy's Avatar
Exactly what I have on my SC in Bridgestone RE11. Fantastic summer tire.
‘07 Mazda RX8-8
Old 12-28-2016, 04:38 AM
I ordered my tires yesterday from Tire Rack: Bridgestone RE11 205/55/16 & 225/50/16.
Got a call from Tire Rack today and they don't have the rears and won't for several months. They said that Bridgestone may be phasing our the RE11's in my size. I changed to Bridgestone RE 71's and according to the tire rack rep, he said it's a better tire and a little bit cheaper.
I have the RE11's on my 944 and I like them but I feel that they are a bit twitchy, possibly because they grab the road more than my last set of tires and also possibly because of my alignment.
Old 12-28-2016, 11:26 AM
GeorgeM's Avatar
Worthy of note... The extra rubber is nice, but then you go from having over 20 choices down to one, assuming they're in stock.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 12-28-2016, 11:56 AM
^ RA-1's also
Old 12-28-2016, 02:55 PM
Re11 no longer being manufactured at least in the rear. 225 50 16
Old 12-28-2016, 10:29 PM
GeorgeM's Avatar
The issue I've found is the 205/245 combo.... Toyo makes the 245, but not the 205 to go with it in the same model tire for the street. If you go up to a 225/50 in front, then the Toyo T1R is available with the 245/45, but unless you have a wide-body or run extra negative camber in front, it ain't gonna work.
I think the RE11 is the only one with the 205/245 combo for the street.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 12-29-2016, 06:51 AM
SilverWT's Avatar
Toyo do currently make T1R tyres in 205/45x16, 205/50x16 ad 205/55x16, it is just that Toyo US does not make them available to you guys. They are readily available in the UK and listed on the Toyo UK web site, Proxes T1-R | TOYO TIRES - United Kingdom (look under the "sizes" tab).
Mark
Old 12-29-2016, 07:12 AM
Dunlop Direzza DZ102 215/50-16 and 205/50-16. I run them on my '75 with 7 & 8" 951 Fuchs.
'75 911S Targa with 3.2 SS motor [] '88 E30 M3
'95 E36/5 318tia [] '95 E36/5 330ti Rogue Engineering
2004 Honda Element EX 4WD 5 spd [] 2015 991 GT3
2015 Fiat 500e [] '06 Ferrari F430 Spider
Old 01-02-2017, 09:05 PM
Anyone knows a good source for p7 205/55 & 225/50 16" near Los Angeles area
Old 10-30-2024, 10:19 AM
avahdani - looks like Lucas tires has them in stock https://lucasclassictires.com/classic-vintage-tires/sports-car-radials/porsche-911-tires/
Old 10-30-2024, 10:45 AM
Thank you
Old 10-30-2024, 12:23 PM
Called Lucas and yes they have it in stock, Thank you Darrin, man is pricey at $385/pc. Is it worth it I know Pirelli is out until next year. May go with PZERO or Micheline instead. Any recommendation? I love the look of the P7 but is it worth the price?
Old 10-30-2024, 10:29 PM
Mr. Merk's Avatar
The P7 has a good period look but 16" 951 wheels aren't period for a narrow body.
What are your goals? Are you looking for grip or cross country driving?
Living in LA with year round warm weather and access to some amazing canyon roads I'd cetainly be running The Advan A052s
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 10-31-2024, 08:24 AM
@turbofan thats my plan. I'll check out the Advan A052 Mr. Merk,
Old 11-01-2024, 08:24 PM
