Alan L's Avatar
Originally Posted by fastricky View Post
So if I understand this correctly the advantage of blipping the gas during a H&T versus what I was doing is the clutch is engaging while the power is spooling down versus engaging while the power is being added assuming the clutch engages at equal revs in both instances?
Basically yes.
On the track I use a combo of both - double de clutch and heel- Toe blipping. I have a 2nd gear that is getting cranky and I can't be excited about doing another g/box rebuild. So when downshifting to 2nd I double declutch and the gear thanks me. Honestly, I find it too much work for every gearshift on the track. But I do blip the throttle with clutch in before releasing the clutch on all other shifts. I usually do this on the road too if I am really driving the SC (compared to a sunday cruise and sluggish shifts). Now that I think about it, I H&T most of the time in the SC.
The reason is when downshifting you are upping the revs once clutch is engaged. That puts a load on the drivetrain and clutch. If you blip the throttle before this, the transition is really smooth and does not suddenly load the drivetrain. Because you are engaging at increased revs. On the track this stuff happens quick and can be quite violent if you get it wrong. But doing H&T is dead smooth.
Your way, if I read it right is that you are raising the revs and about to drop the clutch. On a downshift. That just seems totally wrong. Do you ever feel a jolt?
That is hard on everything.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 11-29-2022, 11:12 PM
fastricky's Avatar
Originally Posted by Alan L View Post
Basically yes.
Alan
Since chiming in on this thread and hearing the replies I've been using every opportunity I drive to get used to using H&L all the time. Now that it's going smoothly in each car, I totally see the benefit, enjoyment of utilizing and am glad for it! Danke all :BEER
'76 912E
'73.5 911T
'72 2002tii
'88 M3
'17 Mini S
Old 12-09-2022, 02:16 PM
