What does the Heat exchanger temperature sensor control ?
Hello, I have a 83 911 SC and the heat is...well...poo. I do NOT have a automatic heat switch, no footwell blowers, nor any type of sensor in the car near the rearview mirror or anywhere else (I've been researching this for two days). So, what the heck does the heat exchanger temperature sensor control.....control, if anything? Rear engine compartment blower works off the heater switch on emergency brake. Bentley doesn't mention it. Oh, and the heat exchanger valves open and shut like a charm. Thanks!
The automatic heat control system has a servomotor that adjust the heat level flowing from the heat exchangers instead of the 2 manual levers.
Where is this sensor located? On the heat exchanger? Pic?
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Porsche 911 heating systems - Philip Raby Porsche
http://members.rennlist.com/imcarthur/heatcomponents.htm Last edited by wwest; 02-05-2016 at 10:56 AM.. |
Schleprock
The sensor is basically riveted to heat "flapper box" that the heat exchangers are connected to. It's #11 in the diagram and called a "caloric feeler"
Kevin L '86 Carrera "Larry" |
Could someone have replaced the flapper box and it came with a sensor from an Auto Heat 911? Is that possible?
The second sensor, either between the sun visors or in the dash, is used to modulate(***) the level of heated air flowing into the cabin in order to control the cabin atmosphere temperature level in accordance with the setpoint. *** Servomotor moves the position of the flapper box vane position. |
But the OP is wondering why he has the sensor on the flapper box but he does not have auto heat?
Schleprock
I have the sensor with wire on the driver's side flapper box only. I do not have automatic heat nor other sensors inside the car. The car is 33 years old, and has had its share of owners, so who can say if what it originally had. I might feel brave tomorrow and try to trace the sensor wire out, if its possible. Should go through the shift tunnel, I imagine. Thanks for the input everyone.
Eng-o-neer
If we are talking about an '83 SC (as listed under your "Garage") it would have originaly had automatic heat, unless it is a Cabriolet.
It would have had the sensor you see near the flapper box and a sensor between the sun visors (9 in the diagram posted above). It would have also had the black control box between the seats with a dial with positions from 0 to 9 plus DEF (the Cabriolet had a black box with a dial from 0 to 3). The single "emergency" manual heating leaver present in earlier automatic heat control boxes was deleted for '83 (the Cabriolet had two manual leavers). Mark |
If the flapper valve on the left side has been replaced, it would be unlikely that they would have routed the sensor wire into the car, so that may be a clue. Removing the sensor will leave some holes in the flapper box, so that it may have been easier just to leave the sensor in place, if in fact the flapper box has been changed. JR |
Ah, hadn't realised it was still an option in the US, standard in the UK.
Mark |
Thread Tools | |
Rate This Thread | |
