Please need help w/3.0 engine not running
Hi- Thank you!! I bought from an estate a 911Sc that has not run in many years- I got it to start but will not stay running-if i pour fuel in flapper and hold open it will run for a then die out- it seems lik it is running lean- i put fresh fuel,new fuel filter,oil- plugs look dirty but i dont think that would keep it from running Please any thought would be appreciated
What year 911SC?
If you do a search here you will find many threads on this. Here's one for starters Help me bring a 79 SC Targa back to life!
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Ok let me check it out thank you
Nj..
Banned
Do u hear pump running with key on and flapper open?
From my seemingly exact experience I found that most of my injectors were plugged up. After sending them in for a cleaning and rebuild the car started up immediately after installing the rebuilt injectors. Hope this helps.
