88 Not going into gear and a clunking noise
I was driving my 88 today and I made a hard shift into 2nd and then it wouldn't go into third. In fact it didn't want to go into any gear so I pulled into a parking lot and messed with it and got it into 3rd. I drove it gingerly without shifting for about 2 miles and then I came up to a stop light. I was able to start shifting normally after I pulled away and continued towards home. As I got closer it started to not want to go into gear again and as I was decelerating and accelerating I was hearing a clunk in the back. I haven't climbed under it yet, I was thinking CV joints but I don't think that would affect the shifting. Any guesses? Clutch? Thanks in advance.
Old 02-13-2016, 02:51 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Oh my, been there done that.
Get under her safely and open the inspection cover and check for bits and pieces.
On my 915, years ago, was out with a Pelican and he could not get into 1st. It turned out that my syncro band snapped and twisted up inside my box and destroy the 1st and compromised 2nd ( IIRC )
Stop driving her until you know what is going on in there.
'85 Carrera Targa
PCA/POC
Old 02-13-2016, 04:07 PM
geoz's Avatar
An 88 would have a G50 box, let's hope that doesn't make the issue more expensive.
cheers
hg
1988 911 Cabrio
Old 02-13-2016, 11:11 PM
Recreational User
porschenut's Avatar
It may be as simple as a loose transmission mount. Or worn out. Check the easy things first.
Old 02-14-2016, 06:33 AM
I pushed it out so I could jack it up and found this.
Old 02-14-2016, 12:08 PM
gearhead
Does it still have a rubber centered clutch?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-14-2016, 12:24 PM
DRACO A5OG's Avatar
Oooh yeah, looks like rubber center clutch remnants, oh good, not as expensive
'85 Carrera Targa
PCA/POC
Old 02-14-2016, 12:39 PM
Recreational User
porschenut's Avatar
I thought Porsche ditched the rubber centered clutch in 1984. It was still used on the G50 cars?!
Edit: Found the answer here - Rubber Centered Clutch Disc
Interesting that they went back to rubber center for the G50 cars, although an improved version that supposedly isn't prone to failure like the early ones.
If that's really rubber from the clutch, how did it get on your garage floor? The clutch disc is inside the sealed bell housing isn't it?
Old 02-14-2016, 03:41 PM
If that's really rubber from the clutch, how did it get on your garage floor? The clutch disc is inside the sealed bell housing isn't it?[/QUOTE]
There is a little window at the bottom of the trans. When I pushed it back it must have got kicked out the hole
Old 02-14-2016, 06:04 PM
guys, i have a 89 with G50. Same thing happened to me today. Hard shift to 2nd, then not going in any gear. Pulled over to try to figure out a way; then I noticed with the engine turned off; i can put it in the gear I want; kept the clutch in and started it. Drove 30 minutes in 4th gear only home.
I hope its the clutch and not the gear box....
For every problem, there is an opportunity
Old 02-15-2016, 01:29 PM
spb350; did you smell something odd? I had this weird smell like burnt rubber.
Old 02-15-2016, 01:33 PM
I didn't smell any rubber. I'm going to check around tomorrow to get some prices, I hope $2000 will cover it.
Old 02-15-2016, 06:04 PM
Alan L's Avatar
Don't put a rubber centred clutch back in. If it is the clutch the clunking is the dogs engaging in the bell housing. Can't remember exactly how it goes but the rubber center takes the load up til the dogs take the load. but without the rubber it is straight metal to metal. Sounds bad but it is not as bad as it sounds. Most clunks like that are undriveable.
But def needs replacing.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-15-2016, 08:55 PM
hey keep me posted, i m also in SoCal, i m also going the replace it and price comparison would be greatly appreciated!
Old 02-15-2016, 10:56 PM
My 88 G50 had the rubber center disc. Changed it out for spring center one.
While you're in there be sure to do the trans updates, shift fork shaft and guide tube.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 02-16-2016, 03:20 AM
So far $2200 - $2700. I've had two shops say you can still drive it, just not hard or more rubber will come loose. My clutch was not slipping at all before this happened. The shops also said the rubber just gets hot and then eventually falls apart, usually 8-10 yrs?. Most of the shops have recommended going without the rubber core. Does anybody here have any regrets ditching the rubber? Thanks
Old 02-16-2016, 05:31 PM
Cory M's Avatar
When you have it apart check the clutch release fork and the aluminum bosses that are cast into the bellhousing. They can bind up and the bosses that the fork mounts to can break off. If that happens they need to be welded to fix. Something to be aware of while it's out of the car. Lots of info if you search.
Old 02-16-2016, 06:34 PM
Alan L's Avatar
You need to ditch the rubber center clutch. They are a disaster. You won't smell any rubber and the clutch won't slip. The rubber is just the shock absorber taking up the clutch load - easing the load on to the drive train. 'Regular' clutches have the springs to do that.
So it is OK to drive - just be easy taking the load up on the clutch. And that will all but eliminate the clunk. But metal/metal is never good long term. but you could comfortably drive it to the garage or where ever you needed to get to. BTDT.
Alan
Old 02-16-2016, 07:30 PM
