Testing Relays
Most will probably know this ,but to test a relay ,it is very easy by just using
regular continuity tester,from post 30 to post 87a ,you will know straight away if it is faulty,i know it is easy to replace a relay,but sometimes it can be a fault in another area.Also great testing bulbs and many other related items. ![]() ![]() ![]()
Thx!
Is there a list for which relays should be red and which black? In my case, '88 Carrera cab and all currently installed relays are of the red variety. |
Only FP relay should be red is what I understand, the rest black. Red has an extra safety circuit of some kind is what I understand
Wayne, is continuity from 30 to 87a doing a complete test of a relay?
I think it's more rigorous if you power 85 to 86 in order to close the switch, and then test 30 to 87?
1986 Bosch Icon Wipers coupe. |
I will add my DME relay notes here:
Sugarwood is correct, all functions of a relay should be tested.
The purpose of a relay is to switch power, that's why it's installed in the circuit. Simply checking continuity between 30 and 87a only confirms the relay I will pass current between those two terminals in its unpowered state, as it should. It doesn't tell you if the relay will switch when powered, which is the whole reason why it's even there. You need to follow Sugarwoods plan of testing. As far as the red relays, having them in circuits other than the fuel pump will cause no harm. They are more expensive, however, so if one needs replacement, and it's not for the FP, replace with black.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Ambitious Outsider
Thx!
1988 3.2 Cab 2005 997.1 C2S |
Give 12+ to 85 and - ( ground ) to 86 and that activates the relay which will connect 30 to 87. You can also give 12+ to 86 and ground to 85 and get the same result. Does not matter which one gets the 12+ or ground. It works either way. Once 12+ or ground is lost it will switch back to 87a and 30.
83 sc cab turbo widebody. 3.5 liter supertec motor, B&B headers, EFI electromotive TecGT, TurboKraft GT35R billet turbo, 964 cams, WM inj, Bell full bay intercooler, Short bell housing turbo 4 speed tranny, roll bar, hargett shifter, |
Ambitious Outsider
Testing Relays
Sorry sugarwood and others for late reply,not sure.Reason for posting this ,
i was adjusting my drivers window,as it has always hit my top targa rubber seal when lifting up, while doing this up and down alot,after refitting door panel etc. went to finally test alignment and no power windows not working, so fitted another relay, great problem fixed. original faulty one is Wehrie, made in Germany part no--911-615-109-01, so i tested that faulty one and the new one i purchased here Porsche dealer $52.00 Ausy dollar,and that is what i found. Thanks for other information you have posted. |
This type of relay has a snubbing (anti-chatter) diode and they only want to work in one direction (has polarity). If it works in the reverse, then the diode has been damaged (shorted). The relay itself may work, but it won't be as protective to the circuit it is in. This feature can be tested with a continuity tester: with + on 86 and - on 85, you'd read low resistance (~<400 ohms), flip the leads and you should read a much higher number (thousands of ohms). If it reads much lower, the diode was shot/"punched through". my numbers aren't accurate, but the difference in the readings should be very large. the schematic drawn above does not depict the diode, but the schematic on the relay picture above does. the pin numbers follow the DIN standard, which identifies pin 86 as 'positive' as opposed to 'common' because of the presence of the relay (and this inherent polarity feature). for example, the coil pins 85b and 87 don't care about polarity b/c they don't have a diode.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
83 sc cab turbo widebody. 3.5 liter supertec motor, B&B headers, EFI electromotive TecGT, TurboKraft GT35R billet turbo, 964 cams, WM inj, Bell full bay intercooler, Short bell housing turbo 4 speed tranny, roll bar, hargett shifter, Last edited by jbrown; 02-17-2016 at 06:54 AM.. |
Edit: I take that back, somewhat. I remember all of the Bosch relays that I bought having a diode in the schematic, but an image search of "bosch automotive relay" shows a mix. Lots of other brands with Bosch style relays do have diodes shown, far more often.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! Last edited by Pazuzu; 02-17-2016 at 07:42 AM.. |
Just to clarify my post a bit, my reference to the diode and color of relay only applied to round relays as those were the type the OP was discussing. The presence of a diode in other shaped Bosch relays is something about which I have no information so your post doesn't contradict mine in any way.
The DIN std designating pin 86 as positive is a convention in this case, but necessary in those relays equipped with a diode. I agree with ossiblue too, but the red / black convention only applies to the round relays - but note the DME FP relay in post #5 isn't red and has a diode. on edit: oops, i missed L.J.'s last clarification
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue Last edited by steely; 02-17-2016 at 10:42 AM.. |
As far as the round black and red relays are concerned, the red relay is the only one with a "back EMF" diode installed! Ergo, when you test a red relay with voltage you MUST respect polarity for pins 86 and 85 or you will burn out the diode. With a black relay, you can apply 12V and ground interchangeably between 86 and 85 as there is NO
diode. Check these pics of relays (by DB_cooper) with the guts revealed for proof! Multi purpose relays
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Merv Porsche 2003 996 Turbo Porsche 1988 911 Carrera |
