grateful user
don gilbert's Avatar
Not for the every one, but to eliminate future probs, I drilled and tapped the threads to 10mil and use hardend allens. Can torque the heck out of them.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 04-04-2016, 07:03 AM
puddy's Avatar
hah wow thats one way to solve the pproblem!
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 04-04-2016, 11:56 AM
Sorry to bump a really old thread, but figured it was better than making another one
I'm going through the same process, was going to change out all of the exhaust studs, this thread has me rethinking that. I have 2 that need replacing, the rest came off clean, maybe I should just leave them.
copper anti seize was mentioned, should that be applied to both the head side and the new hardware? I bought new barrel nuts and copper coated nuts from Pelican. I also bought a dozen new studs, but maybe I'll just replace the 2 bad ones?
Is it advisable to use anything on the gaskets themselves, or just clean up the mating surfaces and install the gaskets dry?
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 04-18-2017, 10:28 AM
911T '72
DeRRis's Avatar
I've posted this before:
When I put my exhaust back on I used these nuts
The fit through your heatexchangers, are less prone to seizing and easier to remove than the allenbolts. They are M8 with a 10mm socket head.
And I installed the exhaust gaskets dry.
Dennis
Good drivers have dead flies on the side windows. (Walter Röhrl)
Old 04-18-2017, 02:05 PM
fred cook's Avatar
Replacing exhaust studs............
There is an easy way to do this, a technique that I learned while rebuilding the engine in my SC. To remove an unbroken stud, double nut the stud and then use a propane torch to heat the head inside the exhaust port next to the stud. It (the head) doesn't have to get cherry red, just hot to the touch. At this point, you should be able to put a wrench or socket on the stud nuts and turn it out. If it doesn't move pretty easily, heat it a little bit hotter. I removed all of the studs from a set of heads this way and did not break a single one! Just remember to use propane and not mapp gas. the mapp gas might get things too hot too soon! Good luck!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 04-18-2017, 05:49 PM
