Hi
"While I'm there" question
Hello Everyone,
I'm in the process of replacing my clutch along with some other things. I have few questions for you. The thermal switch behind the throttle body, PN 930-207-231-00, what is its purpose? What's its function? And should I replace it? Also, the triangle of death... there are no leaks there, but should I replace the gaskets anyways? Or should I go with "if its not broke, don't fix it" ? Let me know your thoughts.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
Slippery Slope Victim
I did when I did my FI refresh 2 years ago. What the heck, it not expensive and "while your in there". Also did the rubber vac lines as well and the TB O ring too.
MikeČ 1985 M491 |
Does it connect to a vacuum line that runs up to the oil tank vent valve? See recent post "Can this valve be bypassed?".
_______________ John 1988 Carrera Targa 3.2 G50 - Sold. 2017 Chevy Silverado K1500. |
Hi
One hose connected to the thermo valve loops back to the rear of the throttle body and the other connects to the vacuum for the fuel regulator and dampener.
Are you sure? Looks like the schematic you posted may be missing some info? See below....of course this is for an 87-89....
