Correct LED Relay?
I was following the steps to replace my turn signal bulbs with LEDs as described in an older post (I solved the LED indicator problem!!) and I still get the 'fast flashing' results as if I had a bulb out.
I know I have to replace the relay with one designed for LEDs. This is the one I'm using. (Amazon.com: 3-Pin CF-13 Electronic Flasher Relay Fix For LED Turn Signal Light Bulbs: Automotive)
For starters, does anyone know if the flasher relay is the one in the left or right side of the picture?
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 02-17-2016, 03:06 PM
For future flasher relay changer-outers, I finally discovered that the flasher relay is actually beyond and below the relay picture on the left. I didn't even see it until I was looking in from the trunk side. You can either reach it from the trunk or you can pull out the relays pictured and then reach it through the gauge cutouts.
As an aside, since installing an EP36, I went from hyper flashing to no response when using the turn signals. I noticed on turning on the headlights that the left side front and rear parking lights don't come on, so I think I've got a little debugging to do.
Old 02-17-2016, 05:16 PM
Get a an EP26 flasher. It works for me.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 02-17-2016, 06:16 PM
I used an EP36. My car is a 1986. It looks like yours is a '77. I wonder if one is preferred for one car or another. If nothing else helps, I will definitely order one and try it.
Old 02-17-2016, 06:19 PM
universeman's Avatar
EP 36 and grounding the tach indicators did it for me, I got hyper flashing and all-four flashing until I did all that
Old 02-18-2016, 05:36 AM
Bulldog9's Avatar
I bought mine from an off road/jeep source. I had added the inline resistor to no effect, but this relay works great.
4-Pin LED Flasher - '97-'00 TJ | Jeep 4X4 Off-Road LED Lighting | Poison Spyder Customs
1976 Porsche 912E http://www.912bbs.org/vb/showthread.php?43391-770-Update
1989 Porsche 944 S2
2020 Mustang Bullitt
Buncha Moto Guzzi Motorcycles
Old 02-18-2016, 08:08 AM
SweetWaterSurprise's Avatar
Going to give the EP36 relay a shot
Old 02-18-2016, 11:42 AM
I think that the relay I purchased is either faulty, the wrong one, or reversed polarity or something. I now an EP36 from the same company that provided the LEDs. If that one doesn't work, I'll try the off road version.
Another detail for Carrera 3.2 owner's is that the ground wire harness trick described for the 70's Porsches doesn't really match up to ours. We have different colored wires going to the turn signal indicators and have a plug going into the bottom of the tach rather than separate spade connectors.
I'll post back when I figure out what the solution is for 85-89 cars.
Old 02-18-2016, 06:19 PM
Just a follow-up. The 85-89 cars don't need the piggyback spade connector solution on the back of the tachometer that the older cars need. So, don't remove your tachometer!
But, be sure that you get the BMW EP36 relay. All you have to do is replace your existing flasher relay with that specific one and it will work fine with LED turn signals. The first relay I ordered from Amazon looked identical, but I only selected 'EP36' and didn't specify BMW. As it turns out, the polarity is reversed on the other ones which is why I had absolutely nothing happening. Now, it works just fine.
Old 02-21-2016, 01:43 PM
famoroso's Avatar
FWIW, I tried this one...
Amazon.com: iNewcow 3 Pin CF-13 JL-02 Electronic Flasher Relay For LED Turn Signal Light Bulbs 12V 0.02A-20A: Automotive
...and it didn't work. It hyper flashed.
Got link to the BMW EP36 relay?
Old 02-22-2016, 05:08 AM
This is the one I got from Amazon that worked. It turns out that it is supplied by the same people I got my LED bulbs from.
Amazon.com: iJDMTOY (1) 3-Pin CF14 EP35 Electronic LED Flasher Relay For LED Related Turn Signal Bulbs Hyper Flash Fix: Automotive
Old 02-22-2016, 05:13 AM
So you posted to make sure to get the BMW EP36, but the Amazon one you now linked is EP35?
Old 02-22-2016, 07:35 AM
Funny, I didn't even realize it was a 35. When I searched for BMW EP36, that's what came up and since it was by the same people that sold me the LED bulbs, I figured it was the correct 36 flasher.
Either, way, it works!
Old 02-22-2016, 07:50 AM
Ordering now, thanks
Old 02-22-2016, 08:05 AM
Relay didn't work for me in my 1982. My stock relay is a 4pin, and the EP35 was a 3 pin.
Old 02-27-2016, 03:55 PM
I guess that 85 is the year that they changed the pins in the relay. I'm not sure what LED relay has been used in the older cars. I think I remember someone using an EP26, but not sure about the year of the car.
Old 02-28-2016, 07:23 PM
SweetWaterSurprise, in the 82, you have to ground the tachometer indicators with a Y pigtail AND use the EP36. That's the combo that worked for me.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 02-29-2016, 06:27 AM
