Help Identifying Black Connector?
I noticed something that isn't attached anymore on my Carrera 3.2 engine after some recent work done on it to repair head studs. The attached picture has a yellow circle around the connector I'm referring to, which is mounted under the idle air valve. It has a wire that goes back and disappears behind the intake manifold.
I'm guessing if I knew what it was or where the other end of that wire was, I'd be able to find it and put it back in place. Anyone able to point me right?
-Neil
Old 02-25-2016, 05:46 AM
I thought that was a test port for diagnostics. Am I mistaken?
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 02-25-2016, 06:32 AM
Useless test port to reference TDC of the top of the flywheel
Bruce
Old 02-25-2016, 06:41 AM
Very impressive! How did you know that?
Bruce
Old 02-25-2016, 07:27 AM
onboost's Avatar
If you had diagnosed, trouble shot and built as many motors as Bruce, you would have known that also.
Just say'n...
RGruppe #180
Old 02-25-2016, 07:35 AM
So it's useless, but that doesn't help me find it. ;-)
Does anyone know where the other end of it is? Maybe a sensor at the top of the flywheel I guess?
-N
Old 02-25-2016, 07:39 AM
Remove the air cleaner and airflow sensor, look down to the sheet metal and there is a locator in the sheet metal. A single 5 mm Allen will pull the sensor. There is a tie wrap holding the through wire to the harness under the injection.
Bruce
Old 02-25-2016, 08:33 AM
