86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
A/C Temperature Switch.
For the M/Y 1986 and others, the a/c temperature switch P/N 911-613-121-0 has been superseded by P/N 911-613-121-1.
Are there any hysteresis, and, low temperature cut-off adjustment screws on this part?
Thanks,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-17-2016, 06:54 AM
kuehl's Avatar
What is the issue or objective?
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 03-17-2016, 07:17 AM
A/C Switch.
Hello Kuehl,
And thanks for your help.
1. To reduce the hysteresis time on the compressor from the factory 6f,
to 10f.
This adjustment, eliminated evaporator freeze-up in our high humidity
environment. (see pic#1).
2. Setting the compressor temp cut-off @ 38f(at the center duct) also helps (see pic #2).
Both of these adjustments were available on the original switch.
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 03-17-2016, 09:44 AM
A/C Switch.
A/C switch adjustment screws.
1986 911 Targa.
Only in L.A.:
Old 03-17-2016, 09:48 AM
kuehl's Avatar
Before you play.
Have you pulled the end of the probe out of the evaporator and
tested the thermostat in a glass of ice?
Kuehl
Old 03-17-2016, 10:18 AM
Originally Posted by kuehl View Post
Before you play.
Yes, on the ice test.
Because I could not find the adjustment screws,
I have yet to install the switch.
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 03-17-2016, 10:33 AM
kuehl's Avatar
"To reduce the hysteresis time on the compressor from the factory 6f,
to 10f."
The hysteresis, or on/off time, is 'system' as well as environmentally dependent.
Once the contacts break (system off, clutch off) the dwell time before the contacts make again will be dependent upon the evaporator core temp, air temp moving through the core and volume of air. On a 100F+ day, the dwell time between when you will feel cold air again after the thermostat turns off the compressor could be quite long as compared to a 80F day.
Have you determined at what approximate temperature your new thermostat contacts break when the thermostat is set to max cold (fully CW)?
Normally you don't have to "play" with the thermostat. Most evaporator freezing issues are related to probes contact in the evaporator core.
Verify at what temperature (the ice test) your thermostat opens its contacts when set to max cold.
Kuehl
Old 03-17-2016, 11:30 AM
I too would like to know if the newer switches have these adjustment screws. My new system can produce vent temps in the 20's on an 85 degree day if I want.....and while nice the system obviously freezes quick. If I could set the cut off so it was at 36-38 even core temp this way...it would be a life saver.
I agree with Kuel, it would be systems/car dependent.....and it would be easy to do. Have the passenger floor board out and a passenger with a remote thermostat....also have the temp switch out.....drive the car with they system on full cold, and adjust the screw so the compressor shuts off when the core gets down to the desired temp (36-38 in my case). Go home and button it all up. Sounds easy enough (in my head )
I did not check mine before install.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-17-2016, 11:50 AM
A/C switch.
This is exactly what I did with the original factory switch.
With the temp & fan switches in these positions.
This was the center duct temp on an 80f day.
The hysteresis on the compressor was:
1. On at 52f.
2. Off at 40f.
I don't think it wise to exceed 38f at the center duct,
as the evaporator might be @32f.
By rotating the temp control to max, I was, like you posted
able to reach temps of 25f at the center duct.
So back to my original question, are there adjustment screws
on the new (updated) switch.
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 03-17-2016, 12:31 PM
A/c
to 10f."
The defective switch is out of the car, so, I'm unable the determine the thermostat
operating parameters.
So, does anyone know if there are any adjustments on the new replacement switch?
Gerry
1986 911 Targa.
Only in L.A.:
Old 03-17-2016, 01:38 PM
Switch.
Don't want to play "Fingerpoken"...........
1986 911 Targa.
Only in L.A.:
Old 03-17-2016, 02:32 PM
ganun's Avatar
That's why I went with a digital controller, can tune the hysteresis accurately, and on the fly from the cabin. Only thing is dunno how reliable over time.
See my old thread.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 03-17-2016, 04:50 PM
