'73 911 T Targa
Cutting carpet in a way it won't fray
I have a wear spot in my carpet where my heel hits (actually it's a hole at this point
![]() I want to cut a square opening in the carpet and insert a piece of hard rubber to provide a harder wearing surface than the carpet. I'm wondering the best way to cut the carpet to ensure it won't fray after cutting. I was planning to use a hot knife to sear the edges while it's cutting, but I'm wondering if there are better ways. Any ideas? |
Having you thought about just laying the rubber over the carpet? How are you planning to attach this said bit of rubber?
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
I have watched upholstery guys make up carpet sets. Edges are bound. But, as noted above, drivers heel pads are usually stitched right on top of the carpet. The real advantage of that is when the heel pad wears out, the stitches can be cut and a new one sewn in.
1990 964 Coupe 1986 Carrera 3.2 Targa |
Retired, finally
Use Oster hair clippers and a #40 blade to shear the carpet from the backing in the shape you want. Rubber cement the rubber mat to the carpet backing.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
Member 911 Anonymous
I use a heat gun to melt off the edges, it works well. Rub off the dingles, no fray.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Use a new blade to start, then latex adesive to seal the edges after you cut them, although its white when wet, it will dry almost clear, you wont notice it, and the carpet wont fray afterwards, its not going to be affected by the heater either once its dry.
As a 16 year old, i was trained as a carpet fitter! Hope this helps. A...
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla Last edited by ant7; 03-18-2016 at 12:07 PM.. |
I cut some carpet on my car and ended up taking the piece to a local automotive upholsterer and he sewed on the edge beading for $10.
There is always the option of dropping in a Rennline track mat.
1982 911 Targa, 3.0L ROW with Webers |
'73 911 T Targa
I think my carpet is a little too far gone at this point to just lay the rubber on top. There's a sizeable divot and there's a hole. I had planned to use pressure sensitive carpet seaming tape on the underside once I got the rubber piece properly inset. The rubber I found is pretty much exactly the same thickness as the carpet.
