Idle position switch question
Idle position switch fails continuity test. Continuity remains from idle through full throttle. Bentley 240-20 electronic test says continuity should only be upon idle.
Would this cause break up/backfire under load?
Thanks, Dave
Old 03-17-2016, 01:17 PM
Does the throttle plate basic adjustment have any relationship to a failed idle position switch? If the idle switch fails in a closed state, replacement is due, correct?
1984 Porsche 911 Carrera
2002 BMW R1150RT
2013 Audi A4
2020 Ford F150 4x4
Old 03-17-2016, 02:38 PM
911-606-013-00-m100 is three weeks ship from our host..... Help!!!!!
Seems a bit much, anyone have any other solutions?
Thanks, Dave
2002 BMW R1150RT
2013 Audi A4
2020 Ford F150 4x4
Old 03-17-2016, 03:00 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Idle switch.
Yes, but remove the wires, and see if the symptoms are still there.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Idle switch
Thanks, Dave
Send member Blackbyrd a pm.
Gerry
1986 911 Targa.
Only in L.A.:
Old 03-17-2016, 03:01 PM
My switch test shows continuity 100% of time! throttle open and closed. As the switch is normally "closed" is it possible the linkage is not touching the switch during throttle opening? Thanks for the feedback Gerry.
Can the linkage be that far off? I can not tell from looking ........
2002 BMW R1150RT
2013 Audi A4
2020 Ford F150 4x4
Old 03-18-2016, 07:11 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Assuming you are talking about your 3.2: With the idle switch closed you won't be able to rev the engine much over 3500 RPM - that's when the fuel signal cuts out. So yes, it will cause running issues.
There is a detailed adjustment process in the WSM, The throttle plate lever should come to rest against the adjustable stop screw. Then the micro switch gets adjusted to just engage. However, the micro switch should not act as a stop itself thereby taking a hit from the drag lever every time the throttle closes.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-18-2016, 07:18 AM
Hi Ingo, thanks for your input. Your description is exactly what is happening to my 3.2. I have tested the idle switch and there is continuity 100% as mentioned earlier. I am going to look closer and see if the linkage is so far off, it it not engaging the switch. I doubt it, but worth a look. Sal has recommended pulling the throttle body(which I have never done) to replace the microswitch. Is there a proceedure on replacing either the microswitch or the throttle body? Or is it straight forward? Thanks to All for your help on this......
2002 BMW R1150RT
2013 Audi A4
2020 Ford F150 4x4
Old 03-18-2016, 07:26 AM
steely's Avatar
Dave,
There is an adjustment procedure in the work shop manual (WSM) that Ingo mentioned.
If your hearing is keen, you should be able to hear the switch click when the TB lever touches the switch to open it.
good luck,
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-18-2016, 07:31 AM
Thanks, yes, I am looking at the manual now. Was more asking about replacement. If I need to pull the TB...or not, which is the recommended way? Never pulled it before and nothing seems to be documented. Thanks, Dave
2002 BMW R1150RT
2013 Audi A4
2020 Ford F150 4x4
Old 03-18-2016, 07:46 AM
Thanks All......switch was just sticking. Gunk all over.....freed up after many pushes with my fingers. Appreciate the help.....I have a lot to learn.
Dave
Old 03-18-2016, 10:31 AM
Something I did - replace the Phillips head screws with Metric Allen head - then at least you can replace and reinstall easier. As I remember some number of the adjustment mechanism screws are difficult to get at.
Sold: 1989 3.2 coupe, 112k miles
Old 03-18-2016, 11:13 AM
Good idea. I did not need adjustment ...
The switch just seemed to have attracted every bit of dirt off the linkage as possible...
Old 03-18-2016, 01:16 PM
famoroso's Avatar
The Amp electrical connector on the opposite end of the switch on mine broke, due to mine missing the connector mounting bracket (that I am still in search of). I was able to repair the electrical connector with the microswitch in situ. Anyway, I am amazed at how precisely the switch is adjusted to the TB lever. You can hear the audible click at the precise moment the TB lever moves from the resting point. Gotta love the precision.
Old 03-22-2016, 04:47 AM
