Ride height different between full and empty gas tank.
Has anyone measured the ride height different (fender lip) between full and empty gas tank? Mine is almost 1/2" on the front.
Fat butt 911, 1987 |
OEM torsions? I can do a theoretical:
1 gallon of gas = ~6lb 21 gallons of gas = 126lb Stock front wheel rate = ~137lb/in * 2 wheels = ~274lb/in 126/274 = 0.46", or your measurement is pretty similar to the theoretical.
Matt - 84 Carrera |
Rescuer of old cars
10-15mm on mine, depending on how low I run the tank. Call it 3/8-5/8". Yours sounds totally normal to me.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Formerly known as Syzygy
With 22mm TBs, I drop almost exactly a quarter inch with 65 to 70 litres of fuel.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Recreational User
This is why it's recommended to do corner balancing with 1/2 tank of gas and the driver's weight in the driver's seat.
Thanks guys.
Anyone else?
