Winter 3.2 Engine Project
Not sure what to do with my 3.2 motor.
Been reading BA's book, but still have a couple of questions. Thinking about 3.4 P/C using mass air flow with DME, headers etc. Another route is to install carbs. How much am I going to gain (if any) by going to carbs vs DME FI. Thanks in advance. I would like to get close to 300HP, I know, but I can dream.
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
i think it was todd at promototive (sp?) who told me he once did a n/a 3.2 for a customer and hit a brick wall at 250hp. he got around it by using a "high butterfly manifold" (?) and got 275 straight away.
when i enquired some time later about the manifold the cost was about $4k!!! i have ba's book - i would follow the mods he suggests - including i think he twin plugged??
Rich ![]() '86 coupe "there you are" |
Hi,
BTW, My first post! ![]() IŽll install single turbocharger for my 3.4 during this winter. Moderate 0.2 boost for 10.3:1 compression engine seems to work. No other mods, only Motronic chip needs "some" tuning. Result should be at least 30hp more. Reliability? Yes, I know one with 20 000km (12Kmiles) since modification (289hp)...and no problems! If you can do it by yourself, (except tuning, you need Motronic specialist with dyno etc.) total cost/hp is very competitive! |
Jim Smolka,
Jim just walk to the Dark Side and Joint us you will never go back,the Dark side gets even Darker as you go theres only one solution T U R B O
10.76@139-1/4 mile 0-1 mile 193MPH I Love to Shine Cars
Metal Guru
Jim,
I read about the 3.2 mod's in B.A.'s book too. Seems like you can get 30 additional HP with intake and exhaust changes for relatively cheap. If I had a 3.2 I'd do that stuff first, drive it a while and them decide if I needed 300 HP. You might come to the conclusion that 250 HP is good enough.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
I've read gearing changes are good for another 50hp equivalent in speed increase.
1980 911SC Targa 3.6L |
HP is NOT as easy as everyone Dreams off,must of the claims and numbers are wayyyyyyyyy of in the real world.
Re: Winter 3.2 Engine Project
Dyno sheet TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Jim,
You could give your 3.2 to me to replace my 2.0 E and go for the ultimate 914-6 - a 3.6. ![]() Rich |
You can get 320hp/277rwhp just with adding a turbo,no internal modifications ,no intercooler,.5bar non adjustable boost
