Scratching sound in steering column?
'86 Carerra Coupé.
I've recently developed a plastic scratching sound in the plastic shroud of the steering column when turning the steering wheel. I've been in there to fix the turn signal/high beam switch and have since also added a momo steering wheel. Each time I've been in there I haven't been able to located the source. Any ideas? Thanks boys. |
Member 911 Anonymous
It is two things, but most likely the Steering Wheel contact ring.
The other as a consequence is the wiper/horn contact switch. ![]() I would replace the first with new that later will help but if the first one is worn it will soon make that annoying scratching sound.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thank you.
a.k.a. G-man
Awesome,
I had the same noise. Now I know what to look for.
Сидеть, ложь, Переворачиваться |
Add some conductive grease. Solved my same issue.
Counterclockwise?
My sleeve disintegrated and fell through. Just took the steering wheel off and pushed a new one on.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
If the above suggestions don't do it. It could be that the plastic bearing may be toast. There is a steel sleeve you can push in. Call Glenn Sager at Pelican. Extension 240. Relatively painless, just remove the steering wheel and a few other bits if I remember correctly.
Counterclockwise?
