douglas bray's Avatar
What's your car weigh?
Always wondered what my car weighed and figured I'd easily find a thread here that was the registry of weights for the various ages and levels of mods. Is there such a thread?
Had the great opportunity to have my lowly '88 Cabriolet atop the tech scales at California Festival of Speed yesterday evening. Went real quick and didn't see the corner weights, but the car itself came in at a total of 2,630 lbs with a full tank and the spare tire. I know that's gotta be a good number....is there somewhere to look to see how good?
Old 04-09-2016, 06:53 PM
Chain fence eating turbo
Not saying wrong, but how is that possible? You stripped some weight out?
My 87 weighed 2750 with no AC or heat, but turbo bits.
Old 04-09-2016, 07:43 PM
My friends call me Phish
i go to my local dump for weigh ins.
my last weigh in for my 1966 912 with a 2.7 with a half tank of gas came out to be 2150.
Old 04-09-2016, 07:55 PM
LOLz.....Yes, stripped I did.
Weight addition list is a short one and looks something like this: Turbo brakes, Cibie Super Bi-Oscar lights, rear coil-overs, longer wheel studs, steel lug nuts and longer lugs, strut brace, big go pedal
Weight loss list is somewhat longer and looks like this: stock fog lights delete, H5 headlights swap for H4, stock wheel swapped to Prototipo, fresh air box and controls delete, center console delete, central locking delete, footwell blower and cover delete, auto-heat swap to manual pulls, stock door cards and pockets swap to RSR cards and pulls, rear seat delete, flapper box backdate, heat blower bypass, A/C delete, tail light swap to 69R, bumperette delete W/welded holes, rocker delete, rear skirt delete, stock full electric sport seats swapped to Sparco Evo III in leather, stock carpet swapped to RS Perlon felt, stock deck lid swapped for ducktail w/alu mesh, and other such lightness.....
Old 04-09-2016, 08:13 PM
Oh, well you didn't state in original post. That makes a lot more sense!
Old 04-09-2016, 08:18 PM
Rescuer of old cars
Arne2's Avatar
Had mine corner balanced last month, 2739 with 1/2 tank. All stock, no weight reduction at all.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 04-09-2016, 10:24 PM
BlueWing's Avatar
Mine came in at 2620 on certified scale. With 1/2 tank of fuel, spare, tools and compressor. I had the Gotti wheels on at that time and not sure the difference with the Fuchs.
I removed an aftermarket AC system but still have the evaporator in the smugglers box. Also removed the heater blower in the engine compartment when I did the SSIs.
Terry
79 SC Minerva Blue ROW
Non Sunroof Crank Window Coupe
3.0 SSIs, Backdated Heat
COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires
Old 04-10-2016, 07:32 AM
Reiver
Reiver's Avatar
'83 SC...2490 full tank of gas...pulled the usual weight...still have orig bumpers (minus the big lumps).
De Oppresso Liber
Strength and Honor 5th Legion
Old 04-10-2016, 08:57 AM
Functionista
manbridge 74's Avatar
My 74 with my 150lbs of meat onboard was 2440 with 1/2 tank. No tools, spare or AC but front cooler.
Large grain or dump scales are usually +/- 20lbs.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 04-10-2016, 09:03 AM
kent olsen's Avatar
My 72 coupe weighs 2210 lbs with 1/2 tank. Many years taking weigh out, much cheaper than putting horsepower in.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 04-10-2016, 09:58 AM
patz's Avatar
full tank 2350 in my fatass cab.
Old 04-10-2016, 10:07 AM
joefrantz's Avatar
My 73 is 2115 lbs. dry, and 2345 wet with 1/2 tank of gas and driver.
There are a lot of weight threads, but like everything on Pelican, they are hard to find with the normal search. I use Google for most searches.
Here are a couple of threads:
What does your car weigh?
How much do you weigh??? (2800#, 85)
Joe Frantz
73 911 T
Old 04-10-2016, 03:55 PM
My stock 72T Targa with a 1/2 tank of gas came in at 2440.
1972 911T/S MFI Survivor
Old 04-10-2016, 03:58 PM
Canyon Runner
70SC's Avatar
lbs.
I got my 70 SCRS down to 2400 lbs. with Full Tank, Full size spare, And a stereo
Old 04-10-2016, 04:26 PM
'84 sunroof coupe, no other options.
17" wheels, PC680 battery, lightweight muffler, 25lb seats, no trunk junk, gas light on.
Matt - 84 Carrera
Old 04-10-2016, 05:09 PM
Forgot about the tools. I have a complete tool set with the original plastic gloves still in the car
Old 04-10-2016, 05:28 PM
gliding_serpent's Avatar
Yeah, my understanding was the the stock 3.2's were 2750lbs. That is the starting number I am using to estimate the weight losses in my 84. Not sure if there is a 915 vs g50 difference (well I know there is, but I am unsure how much each weighs).
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 04-10-2016, 06:22 PM
Eva
911SauCy's Avatar
'78 SC Targa, with roof, half tank, missing a lot of non-essentials
2520
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 04-11-2016, 07:03 AM
When I had my car corner balanced after I refurbished the suspension bushings and such it came in at 2,741 lbs.
That is a 1985 Carrera with full carpets and mats, 1/2 tank of fuel, and most important the full Griffiths AC system with 4 condensers, and COLD air conditioning so I can drive my car all summer in total comfort.
There is no denying that there is no substitute for "adding lightness" for the ultimate performance of any car. But I am no race car driver and I spend way more time driving the car on the road than on the track. I have done over 100 autocrosses and several track DEs days in my car. I do that to have fun and I can't even care any less about running with the fast boys in a track rat. AC is a wonderful thing in 85+ heat and we get a LOT of that.
Old 04-11-2016, 07:32 AM
This was before we got totally finished. I can't find the final corner balance picture.
Old 04-11-2016, 07:36 AM
