How does the factory alarm disable the car?
Does it kill the starter, the fuel pumps, or spark... or all of them. 1986 factory alarm in 930, key on drivers door.
Trying to chase a no-spark condition... have fuel pumps running with plug off rear of fuel distributor and starter cranks.
Ken
1986 930 2016 R1200RS
Old 04-13-2016, 09:51 PM
a.k.a. G-man
Geronimo '74's Avatar
Dang, does it really disable the car??
I thought it just made noise..
Maybe I should start using it more often then...
Old 04-13-2016, 11:27 PM
El Duderino
tirwin's Avatar
There is a diagram in the back of the Bentley if you have it. It interrupts the fuel pump circuit as I recall. I can post a pic later if you need it.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-13-2016, 11:39 PM
Cairo94507's Avatar
Key on driver's door? I find it difficult to believe Porsche installed an alarm key on the door of the car. Do you have any pictures? Hopefully you are saying the alarm is activated by the door locking mechanism on the door. I hate alarms, factory installed or aftermarket.
'71 914-6 #0372
'17 Macan GTS
Old 04-14-2016, 07:03 AM
patz's Avatar
It's in the door jam under the latch. Most of the original factory alarms are kaput. I yanked mine long ago. ten pounds of crappy wire. Good riddance.
I installed a hidden kill switch, park it a locked garage, have a gun and don't take it to dodgy neighborhoods. I also have an arsenal at home and full coverage insurance.
Old 04-14-2016, 07:09 AM
/ˈpɔrʃə/ PORSH-ə Fan
LUFTKUL's Avatar
Not the best pic, but it's on the driver side door:
1984 ROW Carrera Sunroof Coupe Schieferblau
1982 US SC Targa Moosgrun
1977 US 911S Sunroof Coupe - SOLD
Old 04-14-2016, 07:11 AM
The DME (engine computer) and fuel pump get power from the DME relay which is powered by an output from the alarm module. My module started going bad and I eventually bypassed it to keep from being stranded. So, yes, the alarm will affect both spark and fuel.
Old 04-14-2016, 01:07 PM
