When to shift?
Now that I have my new 911 running smoothly I notice most of its power seems to really present itself at about 4000+ RPM. I am not used to running a car up this tight anymore and am wondering if its ok to shift at 5000rpm? I am curious what you long time 911 owners and racers think? I am not worried about the shifting aspect of the high rpms, I am a very smooth shifter I was tought years ago that the 915 gearbox must be treated kindly and shifted smoothly with positive gear lock. I once in the procces of breaking in an engine (in my much younger days) missed a gear in a hot 911 and pop went the tranny! I have learned not to get excited when shifting but to let the gears flow.
Old 12-16-2002, 08:27 AM
911 user
Milu's Avatar
When your engine is warm don't be afraid to rev to the redline.
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 12-16-2002, 08:38 AM
Stay below 3000-3500 RPMs until the motor is warmed up. After that run it to the red line, about 6300 rpms. These motors and tranys were designed to run that way. If you only run the motor up to 4000 RPMs you will ruin the motor.
Friend of Warren
The 915 is a tough tranny, but it does require smooth, positive shifting, with a slight wait between gears. Running up to redline in each gear won't hurt a thing and adds to the enjoyment. As you found out you need to shift at the higher rpm's. Shifting at 5k rpm's is just fine.
Kurt V
Old 12-16-2002, 08:40 AM
rs911t's Avatar
I don't figure the my car's first owner added 1000 RPM extra without intending to use it. 7000 rpm sounds cool
Greg
Old 12-16-2002, 08:43 AM
Rick Lee's Avatar
My new engine has the Raceware rod bolts. I can't wait to give this baby a workout!
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 12-16-2002, 08:45 AM
I am curious about how it will ruin the motor if run only to 4000 rpm. Could someone please explain. Thanks.
Chuck
1987 911 Targa
1962 C182
"Dirt is permanent. You can move it around, but you can never destroy it."
Old 12-16-2002, 09:29 AM
drag racing the short bus
dd74's Avatar
I believe not running the motors at higher RPMs can promote carbon deposits within the engine, which isn't good.
The Terror of Tiny Town
Old 12-16-2002, 11:10 AM
jyl jyl is online now
jyl's Avatar
The motor is also unhappy if given significant throttle under load under 2,000 rpm (mine is, anyway).
So if one used a self-imposed 4,000 rpm, you'd be living in a tight band from 2,000 to 4,000 rpm, which seems like a pain.
I stay under 3,000 until the oil temp needle clears the solid white zone, then I take it to 6,000 rpm routinely. I try to rev it to redline (>6,000 rpm) several times on each drive.
My theory is (1) revving is fun and that's why I bought the car, and (2) if the thing is going to break, let's break it close to home.
Old 12-16-2002, 11:23 AM
Calspeed's Avatar
Hey JYL... Since we both live in the City we gotta get together for coffee and chat Porsches one morning. Maybe get a SF breakfast run or something setup.
Calspeed
Old 12-16-2002, 12:24 PM
jyl's Avatar
Maybe meet up at the first PCA Golden Gate Club auto-cross event of the year? I think it's in March. I'm planning to attend and watch and/or try AX.
Old 12-16-2002, 12:27 PM
Somatic Negative Optimist
Gunter's Avatar
Cool
The first and second gear on these 915's is not s@@t-hot, so, I don't rev. to high from 1st to 2nd, but after that, go higher in the other gears. 5-6000 sounds good.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-16-2002, 02:27 PM
My owners manual has a minimum RPM for shifting. It averages about 2500 rpm (slightly different for each gear) I'm sure that would apply for any year, and would actually be higher for the earlier smaller engined cars.
Old 12-16-2002, 02:40 PM
dickster's Avatar
one of the reasons it is good to run to the line is to give the rods a stretch. if you don't you run the risk of a wear ridge forming in the bore and then you're in danger of breaking a piston ring if you take it to the redline stretching the rods beyond the wear ridge.
personally i like the power of bigger motors (3.2 is BIG in the uk) and like short shifting unless i'm gunning it. that means changing at anything over 2.5k. theres no harm in low rpm, just don't overload and bog the engine.
Rich
'86 coupe
"there you are"
Old 12-16-2002, 02:44 PM
