Help!! in removing 69 steering column
Hi Guys im struggling to get my steering column out , i guess i undo the top two bolts also how do i undo the single bolt underneath. Any advice welcome
Regards jonny
Old 04-17-2016, 12:13 PM
Break-off bolts. Drill part way through and use a short spiral easyout.
206 637 4071
Old 04-17-2016, 03:57 PM
Which side should I drill from the inside of the cab or from the inside of the hood
Regards jonny
Old 04-17-2016, 09:57 PM
The head of the bolt is dome shaped. That's where you drill. Gonna need an angled drilll motor for the inside one.
206 637 4071
Old 04-18-2016, 05:00 AM
abisel's Avatar
Regards jonny
All three are inside the cab. What you see inside the hood area are the weld-nuts of which the bolts screw into from inside the cab. Take off the two-piece steering column shroud and you will see the other two rounded bolt heads.
If drilling and then using an easy-out doesn't work, you may have to weld a nut to the sheared part of the bolt head. OR, try using a vice-grip with a good strong bite onto the rounded bolt head. The vice-grip worked for me years ago.
Another option is a cut-off disc on your hand Dremel to cut a slot in the bolt head. Then the use of an impact driver with a large screw driver blade.
Old 04-18-2016, 06:22 AM
