Rennch on YouTube
Anyone know how to adjust window frames?
Is there a guide? I'd love to see if I can reduce the wind noise as I'm hurtling down the highway. Car is a 1969 911. Thanks!
Michael
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
PM Sent
Been here a while
It's a bit of trial and error.
Most car seems to have a lot of noise where the window frame meets the door at the front edge. Some small felt wedges under the weatherstrip can help tremendously in this area, no amount of window frame adjustment will help here. Hopefully others will chime in. My experience is to loosen the frame adjustment bolts, and when the window rolls up and down well, you are pretty close. That combined with nice looking gaps when the door is closed....that's about as good as it gets. See you soon!
looking for 1972 911t motor XR584, S/N 6121622 |
Cars Ruined My Life
ROW '78 911 Targa
Porsche manual "sealing of 911" PDF
https://www.dropbox.com/s/snxj2bigbm5nmj0/Sealing%20of%20911.pdf?dl=0 And there is info on the coupe in the Targa manual as well. https://www.dropbox.com/s/bbew4u10ax7f8ez/targaroofrepairs.pdf?dl=0
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 04-20-2016 at 07:25 PM.. |
Dennis:
Those are the two I have. Did not know how to post them here. Hence the "PM Sent". I offered to e-mail the books to the OP.
See Timmy2's post above. I offered to e-mail those documents to the OP.
Rennch on YouTube
Yes, let HarryD off the hook! Thanks you guys...I'll have a look!
ROW '78 911 Targa
![]() On a side note I went to C&C a couple of weeks ago to show you my new restored taga top, but no bus or '73 in sight... It's all your fault... I had to do it after seeing yours.
Cars Ruined My Life
the factory service bulletins are fantastic .... the way to get it pretty close is to use a dollar bill...... close the door on the dollar bill in all location and you should feel a tight drag on the bill. If the dollar is too tight, that area might be holding up the door from closing properly and can also cause a leak at adjacent areas. bob
Rennch on YouTube
The dollar bill method sounds fantastic!
