Ferrariguyma's Avatar
Send a message via AIM to Ferrariguyma
I searched and nothing conclusive... Wipers come on when I start the 3.2?
I have a 1986 3.2 and when I start the car, or even turn the ignition to the pre-start mode the wipers come on automatically and do a few passes. I checked the intermittent wiper switch on the dash and it is off. I confirmed it is working correctly. Any other ideas or links to "fixes" would be welcomed and appreciated.
Thanks in advance,
Andrew
(6) cars currently in my garage:1976 Porsche 912E #627 Ascot Green 1986 Ferrari Mondial 3.2 Coupe Brown/Tan 1986 Porsche 911 Carrera 3.2 Paint to Sample Brown/Brown 1985 RoW Mercedes 420SEC C126 Coupe Brown/Tan, 1978 Alfetta GTV with a TwinSpark, 1997 BMW Z3 1.9 Boston Green/Beige 5speed
Old 05-02-2016, 05:45 AM
911tracker85's Avatar
mine does this too, or should I say my wipers will occasionally make a few swipes when driving.
pulled the fuse unless needed.
also my high beams are on most of the time.
I had replaced both some years ago ... sigh...
need to pull both switches from the steering column and fix. I have seen the fix for the high beams, and suspect the fix for the intermittent wiper action will be the same.
need to slightly bend the little contact.
here are a couple links I saved for fixing the high beam issue.
turn signal switch quick fix pictures
Headlight dimmer repair?
good luck.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 05-02-2016, 06:22 AM
Diss Member
Quicksilver's Avatar
Check how clean the ground wires are at the post just in front of the battery.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 05-02-2016, 07:30 AM
+1 on what he said! Had a very similar wiper activation problem when I would use the
turn signals, drove me crazy! Traced everything down with an ohmmeter and a wiring diagram, found a floating ground at the body ground mounting point from the battery negative to the inner left fender.
The floating ground found a path thru the windshield washer motor, causing intermittent wiper swipe! Grounding problems can cause WEIRD problems!
I took off and cleaned all the wires under the grounding nut, several of them were quite corroded. Get a can of DeOxit D5 and use every time you rehookup any electrical connection. It cleans,deoxidizes, seals and protects electrical connections, it's awesome stuff!
Amazon.com: CAIG DeOxit Cleaning Solution Spray, 5% spray 5oz: Everything Else
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-02-2016, 08:43 AM
Fixed!
Thanks for the ground tip. SPOT ON! Much appreciated
Old 05-09-2016, 05:54 PM
Originally Posted by 86 911 Targa View Post
Is your intermittent wiper switch on?
no see initial post
problem was ground
Old 05-09-2016, 06:11 PM
