/ˈpɔrʃə/ PORSH-ə Fan
LUFTKUL's Avatar
Rust Replacement Panels for Fender Bottoms?
Almost rust free '77 except 3 bad spots. Bottom of both left and right fenders and a tennis ball size hole in the pan on passenger side.
Does anyone sell new bottom pieces of the fenders to cut the old rust out and weld in? Do I have to buy a full fender, and if I do, is it better to cut and weld on old fender or just use the new complete piece?
Is this the replacement piece on the belly pan hole?
Part #: SIC-501-006-00
Repair Panel for Bottom Rear of Front Inner Fender SIC50100600 - SIC-501-006-00 | Pelican Parts
I realize the oil lines would need to be removed to weld in the belly pan piece, but how hard is it to get that curved piece welded in properly?
1984 ROW Carrera Sunroof Coupe Schieferblau
1982 US SC Targa Moosgrun
1977 US 911S Sunroof Coupe - SOLD
Old 04-25-2016, 12:12 PM
LUFTKUL's Avatar
Old 04-25-2016, 12:14 PM
Under the radar
Trackrash's Avatar
A flat piece of sheet metal will work to patch the bottoms of your front fenders. Assuming, that the rust is not a lot worse on the back side of the panels.
To do it right you really need to remove the fenders and assess the entire area.
Not sure if that bottom fender piece is still available separately from the fender.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-25-2016, 01:24 PM
You are going to find more! starting with outer rocker.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 04-25-2016, 05:14 PM
Irhmsd's Avatar
⬆️⬆️⬆️⬆️⬆️ I sadly agree. Tip of the iceberg.
2013 Speed Yellow 991 Cab
1974 Silver 911S Targa 3.2
1997 993 Cabriolet
1958 356A Sunroof Coupe
2002 Rover P38 Borrego
Old 04-25-2016, 05:43 PM
Fixer's Avatar
+3
You need to get the fenders off and oil lines out of the way and start removing the undercoating around the corrosion with a 4" angle grinder/wire wheel
until you see bright clean metal.
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 04-25-2016, 06:38 PM
Work in Progress
Rich76_911s's Avatar
I don't think you can get the panel to repair the bottom of the fenders anywhere except here:
Porsche 911/912
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 04-25-2016, 07:19 PM
SCadaddle's Avatar
Beat me to the source by 3 minutes. That's the second time that has happened today!
Porsche 911/912
I think the bottom of the fender is the least of your worries.
Old 04-25-2016, 07:22 PM
Uncertifiable!!!
Uwon's Avatar
Looks like you are going to need some major pieces as well. Here is another source.
Restoration Design Inc. | Quality Custom Porsche Automobile Panels
Good luck.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 04-26-2016, 03:55 AM
LUFTKUL's Avatar
Thanks for leads everyone.
It looks like Wolf Restoration only makes the fender bottoms for F body cars, but I will contact them to make sure.
It seems a shame to cut a perfectly good repop fender just to weld on the fender bottom. I assume that's the best route as my original fenders fit the car.
If anyone has some damaged G body fenders that are good on the bottoms, please let me know.
Old 04-27-2016, 08:20 AM
tharbert's Avatar
I hate to see this. It reminds me of my car which is still on a rotisserie in my shop while the motor sits in my closet in bits.
Get a good awl and start poking around. I think you are looking at replacing part of the floor pan and rockers as well. Look around the pedal cluster, A-arm mounts, front tank support and battery tray, rear longitudinals, kidney and torsion tube. Unfortunately, I agree with the others. The more you peel back, the more you'll find.
If you need just a portion of a panel, post in the classifieds here. I've had good luck sourcing small parts of panels from folks cutting up cars.
Good luck!
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 04-27-2016, 08:49 AM
