What is the "Correct" hose to use for fuel tank venting?
The vent hose on my '74 is old and brittle and I am going to replace tonight. The current hose appears to be clear plastic tubing - is that correct of is it supposed to be vacuum/fuel hose?
Old 08-17-2016, 08:56 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Oh no, it should be fiber wrap fuel line, check the PAG katalog for the part number.
'85 Carrera Targa
PCA/POC
Old 08-17-2016, 08:58 AM
Clear hose looks correct for the mid year car
Old 08-17-2016, 11:47 AM
DRACO A5OG's Avatar
Wow, just learned something. Interesting. I guess as long as it holds up to the fuel.
'85 Carrera Targa
PCA/POC
Old 08-17-2016, 12:31 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Here's my 81.
Supplementary data:
It rubs the lotion on it's skin or else it gets the hose again. Yes she will, Precious. It will get the hose.
1981 911SC Targa
Old 08-17-2016, 12:36 PM
Retired, finally
SiberianDVM's Avatar
My '77 has fiber wrapped hose, but I've always hated the frayed look so I'm replacing it with smooth surface rubber fuel hose.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 08-17-2016, 12:40 PM
moneymanager's Avatar
You've got the original plastic; same as my 74.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 08-17-2016, 02:18 PM
Registered Minimalist
75 911s's Avatar
My midyear had the same clear tube for the vent hose. I tried to move it to install the headlight relay and it burst into a million pieces. I couldn't find the right diameter hose on pelican. I have standard fuel hose from FLAPS that is close but not exact.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 08-17-2016, 04:28 PM
Bob// I have seen a lot of funny replies on this forum !!!! but the hose monster is sick@@@ funny@@@@ but sick ///I never would have thought about that quote and scene for a fuel line you must stay up way to late
Old 08-17-2016, 05:21 PM
HarryD's Avatar
I used PVC hose from my local hardware store.
The late great Jim Sims says:
Originally Posted by Jim Sims View Post
"Regular" PVC (vinyl) hose or tubing is not adequate for fuel or fuel vapor
From the 1972-73 Factory Parts Catalog the following fuel resistant PVC tubing is required:
ID in mm x OD in mm x length in mm
9 x 12 x 140
9 x 12 x 210 (2 pieces)
9 x 12 x 270
9 x 12 x 470
15 x 21 x 220
15 x 21 x 600
the 9 x 12 should map to 3/8" x 1/2" McMaster-Carr 5552K27
and the 15 x 21 should map to 1/2" x 5/8" McMaster-Carr 5552K28 (this PVC stretches quite a bit).
Be careful with the plastic tees and fittings; they may be NLA.
Jim
This is the McMaster Carr Catalog Page for the hoses: McMaster-Carr
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-17-2016, 06:02 PM
75 911s's Avatar
Yep 9mm x 12mm i think is the size. I used 3/8" X 1/2" fuel hose from FLAPS sold by the foot. You will need new hose clamps as the 1/2" OD is too big for the factory clamps.
Also, there's a 'check valve' thingy in the line to the front by the battery. It's a little metal bullet thingy. I'm not sure if it is for smell or keeping fuel going in one direction.
Old 08-17-2016, 06:52 PM
75 911s's Avatar
Old 08-17-2016, 07:01 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Vern, fess up - you didn't really start this thread to ask something as rudimentary as "what type of vent hose to use" butt wanted to slyly show off yer boss, new fuse & relay panel!
Old 08-17-2016, 08:07 PM
Cars Ruined My Life
impactbumper's Avatar
Good point, i am tackling that this weekend instead of kicking back. I will post a picture showing my hose when finished
Old 08-17-2016, 09:08 PM
oh, did I get a new fuse panel? I completely forgot about that.
Old 08-17-2016, 09:53 PM
Mick_D's Avatar
Where is this picture from? I am in desperate need of exploded diagrams with part numbers!
Originally Posted by 75 911s View Post
Old 08-18-2016, 07:43 AM
You can get the pdf off of Porsches website for your car. Look under Porsche classic.
Chris
'75 911s Targa
Old 08-18-2016, 08:06 AM
Mick_D's Avatar
Thanks. I guess that's as complete as I'm going to find, eh? I'm going to want to download at leat two, since my car's sort of an amalgem of a 1975 911 and a 1986 turbo.
Old 08-18-2016, 08:13 AM
My 73 had clear hose, I got a kit from sierra madre
Old 08-18-2016, 09:51 AM
I found clear tubing at Orchard Supply Hardware and it was labeled "for chemicals, fuels, and gasses". I bought 5 feet for $2.25 and that gave me enough room to put all the hoses together at the central block and then cut to fit feeding the hose thru the maze of wiring. 1/2 hose diameter seems to be an exact, snug fit.
Installed:
Old 08-18-2016, 09:59 AM
