Banned but not out, yet..
RSBob's Avatar
Oh you had to go there. . That motor in a 914 should be an absolute blast. Rode in one with an RS spec MFI which was power slid through the corners and I was instantly hooked. Your motor should achieve the same or better results.
Old 07-23-2016, 12:43 PM
al lkosmal's Avatar
Rick...I thought that the 914/6 comment might catch your attention. I build this configuration to be RS spec-ish, but with higher compression, EFI/ITBs and a good ECU (lot's of acronyms there). This combo provides the ability to optimize the tuning.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 07-23-2016, 06:02 PM
Great looking little build. Love the look of the complete motor
Old 07-25-2016, 03:34 AM
al lkosmal's Avatar
Thanks...i appreciate the comments
regards,
al
RGruppe #669
Old 07-25-2016, 11:05 AM
sithot's Avatar
I'd like to be in line for some of that goodness.
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 07-25-2016, 12:10 PM
al lkosmal's Avatar
Give me a shout if you have a project in the works that I can help with.............
regards,
al
RGruppe #669
Old 07-25-2016, 01:50 PM
al lkosmal's Avatar
it is real!!!
OK....I have Dee's 2.7RS+ tuned up nicely. This is really running very strong and should do a great job of moving his 914/6 around.................
https://www.youtube.com/watch?v=_5AOmzwj7DA&feature=youtu.be
9.5:1 JEs
E-cams
TWM/Borla 40mm EFI/ITBs
headers/sport exhaust
Crankfire/EDIS ignition
MS3X ECU (ignition/fuel control)
This will move his 914/6 around with some serious moto-vation. It is now tuned very nicely on my test stand and it is running great.
regards,
al
PS: I have a 2.0E being shipped to me, a 2.4T and another 2.7S in negotiations....getting ready to be made into canyon carver engines. let me know if I can make one of these for you.
Al Kosmal
the x-faktory
koz@x-faktory.com
RGruppe #669
X-Faktory - Home
RGruppe #669
Old 07-28-2016, 01:20 PM
al lkosmal's Avatar
2.7rs+
Fired it up one last time, last night, to warm it up and perform a leak down test.... with excellent results......this one is done and headed to Atlanta tomorrow................
regards,
al
RGruppe #669
Old 08-02-2016, 04:58 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
Beautiful work. It makes me start thinking. How much can I gain adding ITBs and modern injection/ignition to an SC engine with 9.3:1 stock pistons and 964 cams? Am I right that parts for that conversion run about $7000?
Winter is coming.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 08-03-2016, 12:46 PM
AirBorne!
Subscribed
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 08-03-2016, 01:58 PM
al lkosmal's Avatar
Dru,
with no other changes made, I expect that you would see on the order of 10%+ HP increase and 15% TQ increase (more if you also add SSIs and sport muffler). My "full meal deal" S3-EFI/ITB kit with ECU and most everything you need is just over $4K. Changing from Triumph Speed Triple to either PMO or TWM/Borla ITBs will add another $1.2K to $1.5K or so. This is a very complete system. You can check out my EFI/ITB system on my website:
X-Faktory - Home
regards,
al
Al Kosmal
the x-faktory
koz@x-faktory.com
RGruppe #669
X-Faktory - Home
RGruppe #669
Old 08-03-2016, 02:30 PM
al lkosmal's Avatar
on its way to Georgia
Picked up....and on its way to Georgia.........
regards,
al
RGruppe #669
Old 08-08-2016, 08:36 PM
db9146's Avatar
2.7RS transplant recipiant
Here's the car this one is going into. I'm going to pull and pickle the original number-matching engine and trans and swap in the my new 2.7RS and rebuilt side-shifter trans.
Heading off to Okteenerfest next week and then will start the install process once I get back.
Al, I can't wait to post a video to your thread here with the engine in the car!! (if you don't mind)
Old 09-16-2016, 07:54 AM
al lkosmal's Avatar
Dee,
Have fun at Okteenerfest.....can't wait until you install this engine in your teener and fire it up....buckle up and hold on!!!
regards,
al
Al Kosmal
the x-faktory
koz@x-faktory.com
RGruppe #669
X-Faktory - Home
RGruppe #669
Old 09-16-2016, 08:02 AM
db9146's Avatar
its new home
Its in and running. Got the engine compartment cleaned up and freshly painted before putting the new engine in. There were a lot of things I chose to do with the engine and trans out and I added a lot of new parts as the engine went it:
- rebuilt the engine wiring harness to tie into the stock relay board,
- new alternator (and matched regulator!),
- new battery,
- new fuel system (hard lines, soft lines, filters, pump, and regulator),
- ultrasonically cleaned oil cooler with the right new fitting welded on for a -6,
- new engine oil thermostat,
- added some additional sensors to the engine (intake air temp, additional oil temp, and new oil pressure),
- new 1 5/8" stainless heat exchangers,
- new muffler,
- new starter motor,
- new clutch, p.plate, and TO bearing,
- a side-shifter trans (in place of the original tail-shifter),
- new RennShift shifter, new complete Tangerine Racing shift linkage,
- new engine and trans mounts,
and finally, drilled two holes for a couple of 4mm nutserts to mount the EDIS module on the side wall of the engine compartment to hide the electronics, and two 4mm nutserts under the dash to mount the ECU. I wanted to make it look original and not do anything that couldn't easily be undone when putting the car back stock, hence the attention to only 4 new small holes.
My son and I took the car on its first trip this past weekend and it ran pretty well - never hit 210 on a hot Atlanta weekend in the mountains. Still a little more tuning to do and break-in miles to drive with the rev limit now at 4K before we let her rip.
This is the first project of this magnitude I've taken on and while I know this sort of thing is old hat for many of you, its been a steep learning curve for me.
I have to say that Al has been great through the process and has answered many a stupid question. Thank you very much Al!!
Old 09-21-2018, 01:01 PM
