Russ
Did I break it??
Hallo guys,
I was hooking up my gauge and I think I shorted it out the temp side??? How bad is it? Do I need a rebuild? ![]() Thanks, Russell |
Looks broken to me. You can probably find a replacement on ebay or here.
Chris |
Russ
Chris,
Thanks for the confirmation. :-( Do you think it is less expensive to rebuild or to buy another one. It looks like these sell for $250-$350. Thanks, Russell |
Send it to North Hollywood Speedometer for repair.
Kurt |
I ordered a temp/press gauge from DCautomotive $100. Worked on install.
Bruce |
I had a terrible experience with North Hollywood Speedometer so cant recommend them. Sending it out you will get a like new gauge back but will take several weeks. Buying a used one is easier and faster.
Pro's and cons. Chris |
I got one for 40 bucks at Hershey , you have to just not be in a hurry . I don't think its a critical guage for a road car . Just leave it until you get one at a decent price. Don't be rushing to find one this week and pay through the nose.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
wait you should be able to just get the module for inside that .. in fact that's not the original module . that's an aftermarket kit put in to show the numbers. you might be able to get that from Pelican.
Senior Member
As mentioned, that temp gauge is not original to the car (I am pretty sure of this). You can remove just that piece of the gauge and replace with a new one from our host. I did this when I went from the "bar" gauge to the numbered temp gauge you have.
Be absolutely sure the sending unit is a match to whatever replacement you purchase or the reading will be meaningless.
'78 Targa in Minerva Blue |
El Duderino
Can't emphasize this statement enough!
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Russ
Excellent! Thanks for the comments and advice.
Russell |
It is maddeningly hard to find on Pelican. Look for part number PEL-911-TMP-KT1. Comes with a new temperature sensor. $205.
Mark
1979 911SC Targa |
Send it to North Hollywood. They fixed my speedo. I installed it wrong and fried it. They repaired it again for not a lot more money, and now it works fine.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Reiver
That 120 looks very close to the original 140 degree/ 60 Celsius ....I've always wondered about that specific overlay. I've one from a different vendor (overlay only) that matches the original side tick mark of 60 C with the 140 temp marking. This for an 80-83 SC. That unit covers from 74-89 so that sender has to be coupled with that delineation.
De Oppresso Liber Strength and Honor 5th Legion Last edited by Reiver; 05-03-2016 at 04:03 PM.. |
Reiver -- absolutely -- note, however, that the one I linked to looks identical to the one on the OP's initial post --
Dc auto has one for 150.
82 911 SC |
petercory
Being in the instrument field, I can't resist jumping into this chain; just because a gauge is functioning doesn't mean that its readings are correct (most older gauges aren't), thus sending it to North Hollywood or Palo Alto for calibration guarantees that the readings will be accurate. The charge for this service is pretty cheap insurance against potential engine damage/failure.
