"Der Hellion"
roctor's Avatar
Send a message via AIM to roctor
Lightbulb 2.7 Alternator install. Thoughtsand advice.
After reading many threads. My idea would be to double nut alternator studs. Pre-fit, center and tighten alt/housing assembly. Thread wires through air duct and tighten washers and nuts over installed and much more tightened nuts on alt/housing. Roger
Old 05-05-2016, 01:01 PM
76 911S Targa
The problem with this strategy is that you cannot reach the alternator electrical connections through the small air deflector duct. I have not had the alternator stud nuts loosen as they snug against the plastic air deflector housing with lock washers. I have considered making a wire loom that would take the alternator wires to a convenient single plug (or maybe separate spade connectors) outside the air deflector to ease removal of the alternator/fan/housing combo for engine cleaning. If you try your plan let us know how it works.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 05-05-2016, 02:36 PM
Discseven's Avatar
That's a damm interesting idea Targalid. Given a quick disconnect, am wondering if the housing will come out with the air duct attached?
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 05-05-2016, 03:48 PM
76 911S Targa
I am pretty sure it does. The whole problem with removing the assembly is the need to disconnect the wires: the ground cable and the wires to the alternator. Except for the ground cable, the air deflector has to be moved forward to give access to the alternator connections. Otherwise I think the whole deal would come out as one piece.
Old 05-05-2016, 04:37 PM
I slid my air duct into engine, connected wires to alternator and then slid the duct onto alternator and fastened nuts. Tedious , but not a big deal.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-05-2016, 04:39 PM
al lkosmal's Avatar
I recently did this, using a mil-spec connector....i will see if i can find a pic.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 05-05-2016, 04:57 PM
Discseven's Avatar
regards,
al
Al... can you say which Milspec you used?
Karl ~~~
Old 05-06-2016, 05:31 AM
"Der Hellion"
roctor's Avatar
Thanks for input all. Will follow up with reconnection status. Roger
Old 05-06-2016, 05:51 AM
