3.6 conversion engine support
Simple question.......which engine support should you run on a 964 motor in a 1975 911? I as because mine has what appears to be a 964 engine support that has (maybe) been bent a little to work with the car's standard engine support mounting points (and mounts).
Is this normal, or do people leverage a Carrera style engine support? If that how so? I am putting new motor and tranny mounts in mine, and want to make sure I have the support proper at the same time.
Just to add my car currently has the 3 row crank pulley on it...so maybe that prevents the use of the Carrera style support?
Thanks!
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 05-05-2016, 06:24 AM
