Discseven's Avatar
Headlight Washers Not Working
Late '79 with new headlight washers---flush mount type---and neither work. Before installing the nozzles the pump was run and it put out a significant volume of water. Hoses from the T to the washers are new with new clamps---no leaks showing. Water tank was flushed and filled with distilled water. Before installing, I blew into each new nozzle (EDIT: I'll note later in thread that this is an error on my part. I blew into the pressure control valves) and it was very hard but air did pass through. Figured the resistance was to build pressure in the system. I know to turn the headlights on to activate the system. When the washer switch is turned on, pump runs but zip comes out of nozzles. Ideas where to go with this would be appreciated.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 05-03-2016, 08:45 AM
universeman's Avatar
Soak nozzles in vinegar overnight, rinse and try again?
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 05-03-2016, 10:07 AM
Are you sure there is enough water in the tank?
I fought with mine once and was about ready to rip the pump our and replace it. Then I realized the tank was empty. Homer Simpson DOH!
Old 05-03-2016, 01:05 PM
sugarwood's Avatar
My check valves were stuck closed.
Dead windshield washer nozzle culprit: Check valve (not the nozzle or T-fitting)
1986 Bosch Icon Wipers coupe.
Old 05-03-2016, 03:01 PM
Great point -- on my carrera, the headlight washers stop working when the tank falls below a certain level (reserving the remainder for the windshield washers exclusively). See that the OP indicated the tank was "flushed and filled" with distilled water, but a partial fill could keep the water level below what must be the inlet for the windshield washer pump
Old 05-03-2016, 03:03 PM
El Duderino
tirwin's Avatar
Following this thread with interest. Neither my headlight washers nor my windshield washers work. They are among the last of the Great List of Nagging Issues to be Resolved(TM).
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 05-03-2016, 03:21 PM
sugarwood's Avatar
^^ Check your check valves.
Old 05-03-2016, 05:14 PM
Discseven's Avatar
Jas... You serious or pulling leg here?!?!
Karl ~~~
Old 05-03-2016, 05:51 PM
Discseven's Avatar
I could have missed that and joined you in the DOHclub Glen... but not on this one! Tank is surly full.
Karl ~~~
Old 05-03-2016, 05:53 PM
Discseven's Avatar
Originally Posted by sugarwood View Post
Sugarwood... not sure if headlight washers have check valves. I looked at part link in the link above and the check looks like a T. The T on my headlight line is a plain T located behind bumper... no check on it (at least as I recall.) My headlight washers are also not working so that's next on menu.
Karl ~~~
Old 05-03-2016, 05:59 PM
patz's Avatar
Me three on the check valves.
Old 05-03-2016, 06:29 PM
sugarwood's Avatar
Look at the two "T's" in the dead center of the yellow.
Those are the 2 check valves. 91462843300 Both mine were clogged shut.
On the '86 you need to pull these down from under the cowl area.
There is a clip that tucks them away. They are near the nozzles.
The exact configuration is preserved in the photo.
The "F" connector goes into the bottom of the two "T's"
Old 05-03-2016, 06:41 PM
Pull the hose at the washer pump to eliminate the check valves. If there is no pressure, then jumper the pump with 12v to see if it runs. If it runs but no pressure, then drop the tank and check that the pump inlet screen is not blocked with sludge/ algae.
Old 05-03-2016, 06:51 PM
911T '72
DeRRis's Avatar
If your pump passes a lot of water then there could be a couple of things to check. Is the pump still strong enough to work under pressure? Are the valves blocked (# 10 or #16). Are your jets to retrictive?
Dennis
Good drivers have dead flies on the side windows. (Walter Röhrl)
Old 05-04-2016, 02:35 AM
Discseven's Avatar
Sug... your a washer system ahead of me with the windshield. That's a great reference shot---TY. Gona get to windshield after resolving headlight system.
Karl ~~~
Old 05-04-2016, 01:26 PM
Discseven's Avatar
Flushed the system out extensively before replacing parts Rus... so doubt blockage but when I get the bumper off and into this over the weekend, that's a good point to check. TY
Karl ~~~
Old 05-04-2016, 01:28 PM
Try this, do all the stuff you are supposed to do but drive the car! I could not get mine to work then I went for a ride after everything and they spray like you could not believe while driving. !!! Try it.
Old 05-04-2016, 01:35 PM
Discseven's Avatar
Nice reference Dennis. Looking at this I now recall the 90 degree pressure control valves #10, #16) positioned just before the nozzles. Must correct something I said at the outset... I blew into these valves and it was very hard but a small measure of air did go through. (Was not the nozzles I blew into---my bad.) Again, thought the point of those parts was to create pressure in system so I accepted the extreme back pressure being OK. Was possibly a mistake... We'll see.
Plan is to pull the bumper this weekend and check the valves, nozzles, then the pump for pressure and sludge, maybe get some vinegar into the program. Once this system is sorted, will catch up to Sugarwood.
Karl ~~~
Old 05-04-2016, 01:43 PM
Discseven's Avatar
Just been advised by security that dismantling my car in my condo's garage can no longer be tolerated... "individuals are opposed to it." Building's association bylaws do say only emergency repairs are allowed in the garage. Having pushed the emergency envelope long enough, there's nothing good to come now from inciting my fellow condo-dwellers to riot. I'll find a space this week where Porsche-works won't offend others. There's much to be said for condo living. There are also sacrifices like this that are a hard pill to swallow. If you're planning to move out of a house and into a condo... prepare yourself for a new world strapped by a multitude of rules & regulations.
Karl ~~~
Old 05-08-2016, 08:48 AM
wolds's Avatar
When I worked on mine I had to prime them with a 60cc syringe to get all the air out of them and then they worked. Now as preventive maintenance when I know I'm going to wash the car I run mine briefly to keep fresh solvent in the lines. Same with with the window washers
Old 05-08-2016, 09:24 AM
