Packy's Avatar
How do I know if I need a new clutch
My clutch seems to be slipping a little when I engage with a little too much gas. Usually it grabs and accelerates but it's been slipping and revving instead.
How do I know if I need a new clutch?
Thanks,
-P
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 05-10-2016, 08:25 AM
IROC's Avatar
I think you just answered your own question. Unless it is out of adjustment (something to check first), slippage like you mention means you need a new clutch.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 05-10-2016, 08:46 AM
Packy's Avatar
Okay. Bummer. Do you know if there is a way to check visually?
Toluca Lake, CA
Old 05-10-2016, 09:11 AM
Park with nose against a substantial wall, select 5th gear, give it some revs and disengage clutch, If it stalls you don't need a clutch yet.
Thats the Car Talk technique.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-10-2016, 09:32 AM
76 911S Targa
Like IROC says, check your clutch pedal freeplay first, 25 mm as I recall.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 05-10-2016, 09:37 AM
Under the radar
Trackrash's Avatar
There can be different causes for the symptoms you describe. The disc could be worn (too thin). The pressure plate could be weak (spring weakened). Or there could be some friction somewhere preventing free movement of the mechanism.
Assuming everything is adjusted properly.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-10-2016, 10:08 AM
sugarwood's Avatar
And if it doesn't stall? Did you just crash your car?
1986 Bosch Icon Wipers coupe.
Old 05-10-2016, 04:20 PM
sugarwood's Avatar
I would read about clutch cable adjustment. From reading, this seems to be the first thing to check, and can be done at home.
Old 05-10-2016, 04:21 PM
Discseven's Avatar
Packy... visual inspection requires the gearbox and engine to be separated. Pressure plate comes off. Clutch comes out. Then clutch's thickness can be measured for visual confirmation of status. There's no way to "peek" into the gearbox and make a visual determination.
Check your adjustments & cable before bumming out.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 05-10-2016, 04:41 PM
If it's slipping a little and you continue driving it, it won't be long before its slipping a lot.
Old 05-10-2016, 04:49 PM
Diss Member
Quicksilver's Avatar
When you do a clutch you will also do (recondition/replace) the pressure plate, the flywheel, and the throw out bearing, so driving it a little past its "gee it's slipping" point isn't a disaster.
That said there isn't any reason to abuse the clutch to test it. Just put it in an upper gear at a lower speed and floor it. If the tach and the speedo don't rise completely in concert then you are slipping. Take it easy until you are at a point where you can replace it. If you have some restraint you could get thousands of miles out of it.
A couple things to take note of:
- A diaphragm pressure plate will increase the clamp load as the RPMs increase.
- A diaphragm pressure plate will have decreased clamp load if the clutch disk is to thin and if it is too thick. (Yes that isn't a misprint.)
- More clamp lamp load then the engine torque requires isn't generally required. (Prostock drag cars use less clamp load then a lot of "high performance" street clutches.)
Just don't dump the clutch when you are in a hurry. Get it engaged when starting from a stop and then shift smoothly. That is how a sports car should be driven anyway.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 05-10-2016, 05:17 PM
No the clutch will slip, you ARE again a wall.
1991 C2 Turbo
Old 05-10-2016, 05:33 PM
Functionista
manbridge 74's Avatar
When torque loading it helps if you are going up a steep hill.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-10-2016, 06:36 PM
Keen 915 operator
felix83's Avatar
Like previously stated, check adjustment first. If the clutch can't be adjusted, or it's back out of spec after you've depressed the clutch, begin by replacing the clutch cable and helper spring (omega spring) before replacing the clutch. A fairly simple, albeit messy and uncomfortable job.
/Felix
'82 Porsche 911 SC Coupe
'77 Porsche 924 Targa
Instagram: @orebro.classics | @924.resurrection
Old 05-11-2016, 07:38 AM
Tags
clutch
