85911's Avatar
Brake fluid reservoir overflow
I'm working on my brakes on my 85 Carrera and have traced the brake fluid reservoir overflow line to a point behind the fuse block where it goes down through a hole in the inner fender. Where does it end/drain?
Also, in the front of the driver's side wheel well, there are 2 plastic containers. I have looked at every parts diagram in the catalog and I think one is the windshield washer fluid reservoir. What is the other one?
Thanks.
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold
Old 05-12-2016, 12:26 PM
Not sure where the overflow drains. The second plastic canister is the fuel vapor evaporation chamber.
_______________
John
1988 Carrera Targa 3.2 G50 - Sold.
2017 Chevy Silverado K1500.
Old 05-12-2016, 12:31 PM
I believe it serves as a "wide spot in the line" to allow vapors to be sucked back to the carbon canister that is located in the right rear wheel well and allow liquids to drain back to the fuel tank. It's part of emission control system.
Look at page 240-23 in Bentley.
_______________
John
Old 05-12-2016, 12:34 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The overflow drains in front of the windshield washer reservoir. The white plastic tube is held against the chassis tub with some metal tabs. Look under the front spoiler/valance where the front of the chassis tub and side of the chassis tub meet at the corner and you'll see it.
Kevin L
'86 Carrera "Larry"
Old 05-12-2016, 02:35 PM
sugarwood's Avatar
Originally Posted by sugarwood View Post
Oh, and I had 2 questions about something else in the driver's front wheel well.
What are the upper and lower tanks for?
That zip tie is creating a serious kink in the circled hose.
The kink does not show up clearly in this photo, but it's pretty big.
How concerned should I be?
Upper tank is catch tank for gas tank venting. Lower tank is windshield wiper fluid. Since that is fill line to ww tank I wouldn't be too concerned unless severely constricted.
1986 Bosch Icon Wipers coupe.
Old 05-12-2016, 04:43 PM
85911's Avatar
All: Thanks. Bentley 240-23 shows the tank in the schematic.
Appreciate all of your help.
Old 05-13-2016, 08:29 AM
