Thank you!
I did the triangle of death while I had the intake off to replace intake gaskets on my 3.2 there was a bunch of rubber bits to replace while i was in there. it was pretty easy to get at everything when the intake was off. I also replaced the oil cooler seals then without dropping the motor. The car was on ramps in the garage for a week. I took my time and cleaned everything I could get to. The only special tools i had to get were wobbly end metric sockets, 10, 12, and 13mm. Did a valve adjustment while I had sheet metal near valve covers off and now I always remove that sheet metal to adjust valves, makes it so much easier.
Thank you all for your input, and even though it may seem like I poo-poo'd some of the expertise and views provided, all your contributions and the experience that they reflect were very much appreciated.
Don |
18k?? That's it?? Umm sign me up. With the way the market is now 18k is half the going rate, I'll take it!
All jokes aside, the God of Porsche John Walker has spoken, 6k is well worth it in my opinion. 6k will last you another 150-200k miles, and if there are no plans for selling in your near future, I'd say get it done and drive the hell out of it! |
Caveman Hammer Mechanic
Hey,
My car had the standard triangle of death('84 Carerra) leaks. I replaced the gaskets for triangle, breather hose and valve cover. Took me about 3 hours, no engine drop, mostly putzing around, very average hand tools required. The bottom of my motor is now dryer than Death Valley in the heat of summer. All the triangle stuff is very reasonable access, mirror and great lighting helps tons. When replacing fasteners remember to use a torque wrench.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Under the radar
FWIW. I doubt it is the crank/flywheel seal. I would imagine it was replaced when the clutch was done. Those seals will last a long time.
I would be way more concerned about broken head studs, and rubber fuel lines.
Counterclockwise?
Grab a case or 2 of brake clean and go nuts.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Can someone post some links on how to address triangle of death with the engine in the car?
I'd like to read about this. Is this in the Bentley?
1986 Bosch Icon Wipers coupe. |
Still here
Ya know, that's pretty much my thinking as well. Isn't the bell housing integral with the transmission, and pretty effectively sealed when installed? How would oil drip out? Also, if it was that rear main seal leaking, why isn't there any clutch slippage/chatter like there was in every other car that I've owned?
I removed my AFM and the fan duct. I also replaced the intake gaskets prior to the triangle attack. I took my time and worked a little, got up stretched and enjoyed the process. Work at a comfortable pace and don't over do it, it will be there tomorrow.
All I had to remove was my airbox and the MAF to access the triangle area. These parts come off easy and I think it's only a couple of bolts and clamps. I also did the semi-partial engine drop to give more room (I left the AC compressor in place and only dropped the motor a few inches). You'll need a flashlight or two as well a mirror and magnetic pickup tool in case you drop a fastener (you WILL drop a fastener as the area is a bit tight). My car had a leaky thermostat seal and oil breather hose which was obvious once I could get my mirror and flashlight into the area. Once done, no more leaks or smokey heat exchangers! There are plenty of threads on the partial engine drop and triangle of death. I say go for it as if you can do the sound pad, you can do this fix. |
![]() This has been an interesting and helpful thread to follow.
jwill911 Espresso brown metallic `87 Carrera Coupe (sold) Now living in Mississippi |
Wash it down to find the leaks and then make a decision. It might be quicker and less frustrating, to drop the engine if the leaks are under all that intake crap.
It is amazing how a small leak can blow around and look like a major problem.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Cars Ruined My Life
Miami is calling you. I'll help you move.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
