Coloradocurt's Avatar
Wheel Question
Are the Fuchs alloys, based on the design of the back sides, by definition "hub- centric?"
Old 05-18-2016, 09:14 AM
Diss Member
Quicksilver's Avatar
Yes.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 05-18-2016, 09:31 AM
Under the radar
Trackrash's Avatar
The 7 x 16 and 8 x16 fuchs on my '71 are NOT hub-centric.
I'm not sure when Porsche started with the concentric hubs. Carreras?
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-18-2016, 11:56 AM
In other words, are you saying that the studs alone keep the wheel concentric on the hub?
Old 05-18-2016, 01:22 PM
Under the radar
Trackrash's Avatar
Correct. Here is a shot of the rear. There are no "lips" on the hubs, front or rear.
Gordon
Old 05-18-2016, 02:45 PM
Bill Verburg's Avatar
all the 16" wheels are hubcentric, not sure about the 15s but I can't recall seeing any non hubcentric ones but them I don't see wheels from the '64-66 either
The hubs themselves came in several versions
the .03 version introduced in 1967 is certainly hubcentric, and i'm pretty sure that v2 of the earlier .02 hub is also hubcentric
Bill Verburg
Old 05-18-2016, 03:14 PM
Under the radar
Trackrash's Avatar
Well, I hate to dissagree, but the 16s on my car are not. Hard to see in this pic, but there is nothing touching the inside edge of the wheel. It just flat against the hub. Anyway the dust cap would hit the wheel first anyway.
In fact, if you look at the hub on the left in the post above, you will notice the dust cap is the largest diameter facing the wheel.
Gordon
Old 05-18-2016, 06:25 PM
It' the hub that's missing the centering ring, I forgot about the back, your rear hub is certainly not hub centering, the '04 hub appears to be the same as the .06 used from '74 but maybe I'm missing something.
here's a stock '76 front hub, hub version .06 w/ hub centric ring that appears to be same as the .04 hub
and stock '76 rear hub, version .33, this hub was introduced for the MY74 911s
all the 16" Fuchs were hub centered
typical 16" Fuch this is a 9x16ET15, th wheel is centered on the inner edges of the mounts
compare to an early 7R 7x15ET49, same design in back
or an early RSR 11x15
Bill Verburg
Old 05-19-2016, 06:10 AM
Under the radar
Trackrash's Avatar
FYI. My '71's front hub.Maybe Porsche added the lip on the bumper cars?
Gordon
Old 05-19-2016, 08:21 AM
".....typical 16" Fuch this is a 9x16ET15, the wheel is centered on the inner edges of the mounts..."
That is what I was suspecting.
Old 05-19-2016, 08:35 AM
Under the radar
Trackrash's Avatar
So, it seems that when Porsche introduced the 16"s they began the hub flanges? Or was it on the turbo, since 9 x 16" was the turbo's wheel?
Gordon
Old 05-19-2016, 08:44 AM
Vintage Motorsport
RichardNew's Avatar
We need Harvey
Richard Newton
Race Wheels Wear Out
Old 05-19-2016, 09:54 AM
all '71-.73 would have has the .04 front hub which is not ubcentric, the .06 hub which I showed above on my '76 and which is hub centric was used from '74 front and .33 rear also hub centric also from '74
the .04 hub may be mislabled in the hub pics above as it sure looks to have the centering ring
Bill Verburg
Old 05-19-2016, 02:46 PM
Under the radar
Trackrash's Avatar
So that begs the question. Will the older 14" and 15" Fuchs, using the older style three prong cap, fit on the newer cars with the newer style hubs with the centering ring?
Gordon
Old 05-19-2016, 03:23 PM
Gas Huffer
MichiganMike's Avatar
I found that the brakes usually cause issue when installing older/smalller rims on newer suspensions. This was the issue when we upgraded my brakes from '67 912 to '74 911. My old 14" fuchs didnt work any longer....
67 Porsche 912R-STi - Betty White - Instagram: @912RSTi
69 Porsche 911T - Project
04 Ford F-150 FX4 - Boris
Old 05-19-2016, 03:25 PM
It's rare that owners of newer cars will want to fit the smaller/narrower older wheels.
The usual path is to replace 6x15 w/ 7x15 or 8x15 where I've never seen an issue other than w/ 930 brakes on narrower wheels, 7" or less in front.
Bill Verburg
Old 05-19-2016, 04:25 PM
