Rear Quarter Window Seal Orientation help!
Need some help here guys. I had these seals on then thought I had them backwards so I reinstalled them...now half way through I think I had them right.
Does the flag/tab that extends past the vertical portion of the seal sit on the top or the bottom? I noticed a little cutout on the seal for the latches which would mean the flag/tab goes towards the top...which is contrary to some photos I have seen online.
Did the original cars (71) have this flag/tab on the seals from the factory?
Is this right?
And a photo of the car for fun:
Old 05-18-2016, 10:41 PM
I have a similar question. I just redid mine and have those tabs on top.... Once I put in the windows they want to stay out. It take a lot or pressure to push them into the closed position. So my questions are....
Like OP, which way do these window seals go in?
How hard should it be to close the windows? If it should not be hard, how do you adjust that tension?
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 05-19-2016, 05:32 AM
Ok, from what I can tell the early cars didn't have a flag/tab and I think the seal is wrong in my photos. The seal should be installed with the flag/tab on the top and either cut off or tucked away. This would align a small cut out in the seal with the latch mount on the rear of the window and it seems the seal fits better with zero wrinkling on the edges.
Anyone confirm?
Old 05-19-2016, 08:21 PM
