intermittent 3.2
Okay, here goes:
When cold and damp in the morning - seems as though it is not firing on one cylinder. Starts to clear after warm up.
Regardless of weather, during normal acceleration, there is a slight but noticable drop in power between 3500 and 4500 that clears instantly. At constant cruise at around 3000, I can barely feel and intermittentpower change. Electrical it seems, but where to start?
Oh, this is my 1985 daily driver with 225,000 miles on it.
I have searched archives and seen a few disscussions, but not one quite matching my condition.
Any help you can give is greatly appreciated.
Mike
Old 12-20-2002, 08:32 AM
makaio's Avatar
I'm still new to the 3.2 world, but I just read a post that said to check the distributor cap for moisture.
If you park your car outside overnight, this could be a possibility. And since you say that it goes away after driving for a bit, it sounds like a likely culprit.
Disclaimer: if this is the cause, credit should be given to John Walker.
Old 12-20-2002, 08:45 AM
I had the same problem whenever the engine got wet it would sputter. Turns out my ignition cables were bad. Get yours changed and see what happens.
Cheers,
Joe
Old 12-20-2002, 09:07 AM
I had aggravating wet weather probs and just changed the cap/rotor and plug wires/plugs. The problem went away but not sure which was the culprit. The flucuating power at 3,000 rpms "MAY" be O2 sensor related. I seem to remember the O2 sensor causing symptoms like that.
Good Luck
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 12-20-2002, 09:11 AM
