LinkBack | Thread Tools | Rate Thread |
I bought new (not refinished) 16 x 9 fuchs for the rear and moved my 16 x 7 to the front.
The finish on the new wheels is a flat black where my 7" is semi gloss black. Any tricks to make the flat go semi gloss? I have heard somewhere about vaseline but I am not sure of what I am talking about. ![]() Any comments welcome. ------------------ David 1988 911 Carrera Coupe Leonoff Net |
David,
The Vaseline rubbing treatment has been recommended for the bare anodized portion on the outer edge of the rim, but I don't know what the official position is on the painted centers. How about a good carnuba wax? ------------------ Warren Hall 1973 911S Targa 1992 Dodge Dakota 5.2 4X4 parts hauler |
David, can you post a picture of your 88 coupe with the wheel change? I was thinking of doing that myself. What was the $$$ damage for the new wheels?
I did the vaseline trick and it helped a lot.
I just wonder how often I'll have to do it. The upgrade was expensive. each wheel is $675. Plus I bought brand new tires and inlaid crest center caps. Was it worth it.....YES! Here are some pics of the car. ![]() ![]() ![]() ------------------ David 1988 911 Carrera Coupe Leonoff Net [This message has been edited by Periokid (edited 10-11-2001).] |
David--
suggest perhaps giving car care specialties a call. 877-796-8300 or www.carcareonline.com I had a similar question last month about my old ('85) fuchs. they told me that (usually) fuchs are finished with wurth matt lacquer, since the lacquer has a much higher heat tolerance than enamel. also said that I could consider spraying on wurth clear lacquer if I wanted to have a high gloss (I don't) their advice was to use some 3M hand glaze and then put a coat of wax on the wheels. I had never considered waxing the wheels before, but the guy said why not? its painted and anything painted can benefit from having a coat of wax. I did glaze and wax my targa bar with mixed results. Had much better luck using vinylex on it. hope this helps ------------------ Steve '85 911 Targa |
Schleprock
3M hand glaze followed by Meguiar's 26 liquid made my flat black Fuchs look like satin or semi-gloss black. I now wax and/or glaze the wheels each time I wax the car. Helps avoid water spots and brake dust stains.
BTW more people need to be aware of the 3M glaze. Does a great job of deepening the color and hiding fine scratches. Follow it up with a good NON ABRASIVE carnauba wax (Meguiar's, Mothers, Malm's, etc.) and I think you'll be pleased. Doesn't last forever. Then again, what does? Anybody want some Zymol? That stuff is a PITA. I have no patience for something that not only expects you to wait for it to haze/dry for 2 min., but to wipe it off in the opposite/perpendicular direction. Please. I have better things to do besides watching wax/polish dry. ------------------ Kevin 87 Carrera coupe [This message has been edited by KTL (edited 10-11-2001).] |
Hey the car looks great. So far I have been lucky still and have managed to keep mine. any other upgrades? I added H4's to mine but still the same.
------------------ 86Carrera 01 saab Viggen 95 Wrangler (winter Porsche) http://doofdog.homestead.com |
David,
Nice look! I really like the deep lips. What type/size tires did you mount? BTW, nice exhaust tip. what type of exhaust? Mike |
David,
Where did you buy your new Fuch wheels?? I have a 1985 carrera targa, what size can I go up to with out altering any thing? Thanks, Mark |
![]() Quote:
![]() I did a 930 steering wheel, new shift knob, a new stereo (original was shot) and the wheels. Check out my web site if you want to see pics. Oh I did a brake job too. ------------------ David 1988 911 Carrera Coupe Leonoff Net |
![]() Quote:
I have 16 x 7 fuchs up front with 205/55 16 and 16 x 9 fuchs in the rear with 245/45 16s. Fits great. No fender rolling, etc. ------------------ David 1988 911 Carrera Coupe Leonoff Net |
![]() Quote:
The exhaust is a GHL muffler. It had to be returned because it did not fit. They made modifications but I still had to modify some areas under the car to make it fit. Sounds great! ------------------ David 1988 911 Carrera Coupe Leonoff Net |
I have made a lot of changes to my 911 page.
Click on Leonoff Net below for some higher quality pictures of the wheels and other items. ------------------ David 1988 911 Carrera Coupe Leonoff Net |
Oh I forgot,
Anyone want my old wheel spacers/adapters? ------------------ David 1988 911 Carrera Coupe Leonoff Net |
Driving member
Nice car David.
My car is an 86 but is identical,color etc. I like the way those wheels fill up the wells. One of these days I will probably do the same but my todo list has quite a few things before I change the wheels. ------------------ Jerry '86 carrera coupe |
I would love your old adapters and will even pay a reasonable price for them. I sent you an email to the adress on your website. Thanks.....
Does anyone know if I can use 16 x 8 & 16 x 10 on my 1988 Targa
I have seen 10” wheels on a carrera (custom ordered fikse wheels). It requires a fair amount of modification. Think rerouting oil lines using the elephant racing lines that relocated them to a higher position. The car I saw also had things like shaved down bolts on the spring plates as well as other suspension mods.
1982 911 Targa, 3.0L ROW with Webers |
wheel paint
Getting back to the original subject...
I painted the center inner part of a mesh type wheel with GLOSS black wheel paint that does not match the outer part of the wheel...which is semi gloss. Any suggestion as to how to turn a gloss to semi gloss? |
Thread Tools | |
Rate This Thread | |
