Do I really need a new alignment job, not a Porsche
Guys,
I went to this alignment place several times and still feel that it's not "right" with my butt dyno , paid, because I waited longer than the guaranty period. So, I went to a new place and remembered to request a print out. Do you guys think I need a new alignment job?Note: this is a Toyota Sienna van. Thanks. What do "before" and "actual" mean? What is SAI?
Fat butt 911, 1987 Last edited by rnln; 06-03-2016 at 04:25 PM.. |
Under the radar
What did the tech say about your current settings?
Are you having tire wear problems? Or handling or squealing issues? SAI = Steering Axis Inclination, not sure if this is adjustable on you car. Probably a check for bent struts. I think that -2 deg camber on the rear is excessive for a mini van.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 06-03-2016 at 06:28 PM.. |
I think "before" is what it was before the alignment was done and "actual" is the reading post-alignment.
If I'm right then I would be concerned with the fact that the alignment didn't seem to get some of these readings into spec. "Actual" shouldn't be out of spec. This may help interpret some. Understanding Reading Alignment Specifications. This article also said: "If for whatever reason your vehicle can't reach within the acceptable range, replacing bent parts or an aftermarket alignment kit will be required." Tire Tech Information - Alignment. You might have some damaged parts. Anyway hope that's of some help.
Frank 1989 911 Carrera Targa 3.2L, all stock 78k miles (as of Dec 2023) "The Machine" |
this is the reading/check only at the new place. I have done alignment with the other place several times, but this time the steering whee jump/shake at high speed, around 70 mph. I have not done the alignment with the new place. that is why I confuse about "before" and "actual". They should be the same, right?
Of course the tech told me that I need an alignment.
Fat butt 911, 1987 |
Member 911 Anonymous
Well, you got a base reading to figure out what is going on and where to go from there.
The symptoms you described sounds like a shock/strut issue or a worn out steering rack bushing or control arm bushing. Raise the front end safely, push and pull the wheel to check if you can see where it is faulty. When my Lexus steering went crazy it was the control arm bushing and steering rack bushings that deteriorated. The chain stores will not tell you this until they can not fake align anymore. For the rear, it could be a bushing gone on a control arm or you will need a camber kit as the rears are fixed on Toyotas
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Take this to a Toyota Forum. If your model has specific flaws, they will be known.
LOL, he only trusts us
on a Sienna the rear is not adjustable at all. The castor is not adjustable on the front and the camber is pretty good. The toe is out. This looks like a hunter printout and it shows that the toe is still out and not adjusted. is the steering wheel straight because it looks as if it wasnt centered before the readings were taken, one side is toe in and one is toe out.
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
Wer bremst verliert
The stereo on my subaru keeps turnng off by itself....oh sorry I will take it to NASIOC.
Whats NASIOC for Toyota minivans? Or try Off Topic Discussions - Pelican Parts Technical BBS
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
this, answer for me. Thanks.
![]() I tried checking bearing by yanking the wheels, but have not jacking it up. I went to Toyota and Lexus in the past for several other issues, usually without a result. Thanks guys, so looks like the current alignment spec, good or bad, doesn't make my steering wheel jump/shake
Fat butt 911, 1987 Last edited by rnln; 06-05-2016 at 01:22 AM.. |
I would rather be driving
steering wheel shake is most often a tire balance issue and/or worn shock issue. Not usually related to alignment unless the tires are worn and cupped from being out of alignment.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I had a sienna that had chronic front wheel shimmy. Bugged the crap out of me. Turned out It was simply tires. Seems they are sensitive to tire condition. My solution was to sell the sienna and get a cayenne
thanks guys
I'll come over and take a look :-)
