915 Transmission - Can't Get Into Reverse Easily when Warm
I recently replaced my transmission fluid (a late follow-up change after a rebuild 2 summers ago).
Now I have a problem where, when the transmission is warmed up, the reverse gear is spinning too fast to engage reverse. It has no synchro, so I have difficulty getting it into reverse gear without grinding. Everything else seems to be working well. I'm not sure if the fluid change is related - hot summer weather began at about the same time. Is this likely a sign that I need to replace my clutch? Or is it probably just a clutch adjustment issue? I found another thread (Another clutch issue thread) that seemed to indicate an adjustment was in order for a similar issue. This is getting awkward in public - everyone looks at you funny when you can't seem to drive your fancy car properly.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
I would rather be driving
sounds like your clutch is not releasing fully. You should be able to push the clutch in, count to 5 and then engage R without any grinding.
Have you adjusted the clutch properly?
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Here's another thread I found which indicates I should also check my pedal roll pin (Clutch Fork Broken or Adjustment Problem?).
I hoisted her up and found the source of my problem last night.
There are two bolts which hold the clutch cable sleeve's end on the bottom of the transmission. The pedal-side bolt had backed off about a centimeter, and as a result thrown off the clutch adjustment. Pushing the pedal to its stop didn't fully disengage the engine. At first I didn't see this. I took out the board above the pedal cluster and adjusted the bolt between the levers. With this extra clutch distance, I was able to engage and disengage. Then I spotted the backed-off bolt (in red). ![]() After pulling the sleeve back into position, I was able to fully disengage the engine with the floor board back in place. I still need to adjust the floor stop, as the pedal motion is now overly long. But pushing down the clutch is now fully disengaging the engine and I am shifting better than ever.
Member 911 Anonymous
Oh congrats.
I always try to consciously stop the gears before going into 1st or reverse by tapping 2nd. Just good practice for our delicate 915s
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
What do you mean, stop the gears by tapping second'?
Not literally stop but by just touch the other gears, it is enough to slow the gear box down enough to allow a smooth "IN" to a gear, especially reverse. Try it.
Start the car, clutch in then go to any gear but not all the way in, "just the tip" ;-) then go to Reverse. It will just plop right in. When I test drive my buddys' cars and know that they have some gear issues, I always do this so I do not grind gears. So far so good
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-09-2016 at 08:05 AM.. |
"Touching" the gear basically engages the synchro ring against the shift sleeve but doesn't compress the synchro or bring the dog teeth into engagement. Reverse doesn't have a synchro ring, so you are "borrowing" the synchro from another gear. It might be easiest to "borrow" 5th's because it is faster to swap back to reverse, and 5th probably sees less use anyway.
I've found that with my shift adjustment, the shaft isn't moving at all after I fully clutch and pause a couple seconds. It is amazing what a proper adjustment can do for the shifting feel.
:-D I like that explanation better and like the idea of borrowing from 5th, makes sense.
