Ubi bene ibi patria
Hawkeye's-911T's Avatar
Tensioner Quandary
The engine & car have not been run for nearly 20 years. The mileage on the the clock is 153,000+ & has not functioned for who knows how long. I would like your opinions or advice as to my options & the steps to take re: the chain tensioners. The car will never be tracked as it was hardly an eye-watering performer to begin with. So with that in mind:
L.H.S. cam & tensioner with the tensioner ‘piston’ measuring approx. 1/2” (13mm) exposed.
Tensioner arm has about 7/32” (5mm) clearance from chain box housing.
R.H.S. cam & tensioner with the tensioner ‘piston’ measuring approx. 1/2” (13mm) exposed – same as L.H.S
Chain on idler arm sprocket has approx. 1/4” (6mm) clearance to underside of ramp.
Are these measurements within acceptable safe & normal operating limits?
Do I refurbish the tensioners before I install the safety collars or just leave them as they are?
I will be replacing the chain ramps as recommended by many on the board. I previously purchased a new set of ramps & safety collars from our host.
Any help or advice will be greatly appreciated. Thanks in advance.
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 03-13-2015, 04:55 PM
Put a set of the last generation 930 tensioners on with appropriate spacers and ramps etc. Rebuilt is ok.
Use 60wt oil. Why take a chance on destroying your engine.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 03-13-2015, 05:45 PM
Get the antique chain rails replaced and put a set of tensioner guards on for safety.
Bruce
Old 03-13-2015, 06:06 PM
Ubi bene ibi patria
Thanks for your responses guys. The remedial steps discussed will definitely be taken. However, I still have an uneasy feeling about the tensioner plunger/piston extension from the tensioner. I have scoured a large number of threads on the subject but I'm still unable to find or determine a definitive number for the upper limit of the plunger travel - the worn chain scenario coming into play.
Am I being overly concerned with this 'perceived issue', or should I proceed as planned & then enjoy a cold brewski?
Once again, many thanks.
Cheers
JB
Edit: I took a flat blade screw driver to one of the chain guides this morning - it was really "bendy"
Old 03-16-2015, 09:43 AM
tharbert's Avatar
Bruce has way more experience here but... When I opened up my chain towers the first time, one of my tensioners had a collar and the other didn't. Fishing around in the sump. I found all the pieces. The collar was broken, sheared at one of the bolts. It could be the PO trusted the collars even after the tensioner had failed and the resulting pounding was too much. In any event, I'm not a fan of them.
I suggest along with the rebuilding the tensioner that you look into the Jerry West mod, placing a shim inside the tensioner to limit it's collapse rather than using a collar.
2¢...
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 03-16-2015, 10:32 AM
Under the radar
Trackrash's Avatar
I am still using the same tensioners that you have and have put almost 200K miles on them, BUT I have rebuilt them three times over the years. Those style tensioners only have a small reservoir of oil, which does not last forever.
Collars are a very good idea, they likely saved me once.
The chain on the right side of your motor is nearing it's limit due to wear. The chains will get longer as they wear.
I imagine that you will be looking at a major overhaul of your motor at some point in the future. At that time you may want to upgrade your tensioners as well.
So to answer your question: rebuild your tensioners and add collars now before running the motor.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-16-2015, 10:59 AM
Best Advice ^^^
The tensioners pictured were aftermarket replacement items, they are not genuine Porsche and not 930 tensioners.
I doubt they can be rebuilt, nor would you want to. Replace them.
The chain ramps pictured were the worst type Porsche ever used, should definitely be replaced before they literally fall apart.
If your chain sprocket supports are not bushed, replace those as well. They were a major cause of tensioner problems.
Jon B.
Vista, CA
Old 03-16-2015, 05:22 PM
Ubi bene ibi patria
This is starting to sound & become more expensive by the minute. I was leaning toward Flat6pac & Trackrash's advice. The situation in which I find myself now, is becoming less & less clear. It looks for all the world, I am heading down a very slippery slope.
Cheers
JB
Old 03-16-2015, 08:30 PM
Genuine Porsche chain tensioners since 1968 had a Porsche trademark ("P" inside inverted triangle) cast into the housing.
930 tensioners had internal improvements from previous versions, and reinforced housings (red arrow).
Your tensioners are inferior 1970's aftermarket replacement items.
Jon B.
Vista, CA
Old 03-16-2015, 10:19 PM
Under the radar
Trackrash's Avatar
Update
Repair kit found here. Porsche Chain Tensioner Repair Kit: Engine Mechanical &amp Timing and Related Parts
Porsche 911 Chain Tensioner Repair Rebuild Kit
Part No: 91110590101
Gordon
Old 05-28-2016, 08:00 AM
hello thanks for picks (Trackrash).- have you de second pic, in full sice??? and other page of this manual.- Instruction of rebulit.
What parts, of this is more comun fail??? What part i will check???
In Argentina i can´t buy this kit (or buy in other country, custom is close), i will try find and buy o´rings, but i don´t know what tuo do with the springs.- Replece with similar new or put used again???
regards
Enzo
Old 06-01-2016, 09:04 AM
Under the radar
Trackrash's Avatar
I think all you will need are the o-rings. If it can't be easily depressed when you fill with oil and bleed it, you should be good to go. Here is the Porsche workshop manual instructions.
Gordon
Old 06-01-2016, 03:59 PM
Under the radar
Trackrash's Avatar
More
Gordon
Old 06-01-2016, 04:15 PM
Hello
thanks thanks Trackrash
you realy help me.-
best regards
Old 06-06-2016, 10:11 AM
Hello
i have mechanic tesioner in work order condition (in 2,4 engine from targa 1972), but i don´t know, how old they are or how kilometers.- I buy safe collar; but i think maybe i can rebuilt them before put safe collar.- O better, i can put safe guards inside of them (than pressure - fed tensioners).- Because i read some safe collar can brakes.- You know is posible put inside guars in mechanic tensioners??
regards
Enzo
Old 06-06-2016, 10:14 AM
Discseven's Avatar
JB... here's a look at '79 930 clearance.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 06-06-2016, 04:04 PM
