Speedometer Removal
Hi,
I've got an '88 Carrera with a dead odometer. The speedometer is still operating normally, so I suspect the gears inside the gauge. But I need to remove it from the car first. I've attached a photo of the back of the gauge. I'm not sure how to remove the wires that terminate with the cylindrical red plastic connectors. Looks like you can slide them off to one side perhaps, but I'm reluctant without more knowledge. Can anyone help?
Regards,
Bill
Old 12-30-2009, 12:40 PM
Friend of Warren
Tiny screw driver or edge of knife. Pry up on metal lip not the red plastic piece.
Kurt V
Old 12-30-2009, 12:42 PM
Thanks. Definitely sounds like you have been there, done that.
Let me ask you another, related, question... Is it normal to see connectors in the hole vacated by the gauge that are not connected to anything? I see 2 female butt connectors (a Y), one female blade connector, and one male blade connector hanging out in space. The latter is housed in a protected plastic well. I was very gentle when I pulled the gauge out. I hope I didn't inadvertently disconnect anything when doing so.
Thanks, again.
Old 12-30-2009, 01:28 PM
Friend of Warren
I suspect the wire that was not connected was for your annoying CASIS shift light. Should be a black wire.
Kurt V
Old 12-30-2009, 02:10 PM
I am in the process of removing my speedo tp send to North Hollywood Speedometer to replace the odometer gear on my 87 Carrera. I have all the wires and bulbs out except for the ones with the black sheathing. Do these just work loose individually or do they all come off with the nylon block? Thanks!
Old 07-03-2010, 09:55 AM
5String
The black wires, those plugging into the red plastic pieces, are the bulbs that illumiinate the speedo. They come out WITH the nylon block, and with the metal ring at the base of that block. Just carefully pry them away from the body of the unit with a fine screwdriver blade.
5String
Tell not a soul that you have seen me; breathe not a word of what I say....
The Northwest Files
Old 07-03-2010, 10:09 AM
Okay I have the bulbs out, but the wires with the black covers in the back going into the white nylon block are a little tight. I'm almost certain they just come out individually with a little force but I hate that feeling when I have been forcing something that was never meant to come apart .
Old 07-03-2010, 10:29 AM
The search feature is your friend. There are lots of good threads...
Old 07-03-2010, 10:31 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Speedometer
WHEN RE-INSTALLING:
1. IGNITION KEY "OFF".
2. RECONNECT THE RED/BLACK WIRE LAST.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-03-2010, 10:43 AM
Just wondering why that wire should be connected last?
I replaced the dry rotted and crumbling clear plastic odometer gear in my speedometer and I didn't reconnect the wires in any sequence, I really doubt I connected that one last and it works perfectly fine.
The gear that runs off the odometer motor worm gear was $20 from Palo Alto speedometer a couple years ago and is easy to replace. I think you can buy it from Pelican too. They all eventually dryrot, the amount of time it takes depends on climate and humidity.
For some reason that clear plastic gear is a different plastic than all the other white plastic gears and after around 20 years it turns into wax and the teeth crumble off leaving you with no odometer.
Old 07-03-2010, 11:03 AM
Just a precautionary step.
I was advised by our local speedometer/gauge shop that connecting the power wire first
may damage the IC.
This could be a real issue on the earlier cars as the IC is no longer available.
1986 911 Targa.
Only in L.A.:
Old 07-03-2010, 11:12 AM
I got it out. The black wires just come loose. I was a little shy after yanking on the bulb wires only to go back and research that you have to pry the whole light sockets out.
I have another question which I have already searched. My speedo stays at O mph and then comes alive at about 30mph after moving along. Seems to be a common problem but I never found a solutuion. Just wondering if this was something that needs to be repaired when I send it in. Thanks for the replies everyone.
Old 07-03-2010, 06:47 PM
My car is the same. I have never heard of a solution.
Old 07-04-2010, 07:19 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Stealing this thread to get an answer to a question I got no responses to and which is not covered in any of the threads. Where does the big black rubber piece (circled in the picture) go? It looks like it goes over one of the bulb channels, but I can't figure out which one.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 07-04-2010, 09:09 AM
rs6er's Avatar
As ususal, I figured out the answer to my own question. I hadn't realized that rubber piece contains the green light at the top of the speedo, so it goes into the long shaft directly opposite the odometer reset switch.
John
Old 07-04-2010, 11:49 AM
dshepp806's Avatar
rs6er: are you repairing your odometer? Or what?
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-04-2010, 12:03 PM
rs6er's Avatar
shepp806
Yes just replaced the gear. Now it's all back together.
John
Old 07-04-2010, 03:38 PM
I just had my gear replaced by north Hollywood. I was very happy with the work. You cannot tell they were ever inside. Even the locking paint on the screws looks undisturbed. I didn't mention that the speedo is dead until 25mph hour but now it is fixed and works at all speeds. Now if I could just figure out why the bulbs don't work.
Old 10-02-2010, 07:23 PM
RSM-M491's Avatar
So the wires at the bottom do not come off themselves, you remove the entire part off the odometer? I am referring to the wires with the black sheath, and the power cable. Take that screw off and pull the entire area off? I am getting ready to send mine to Hollywood as well, and want to make sure I know what I am doing before I jump in!
Thanks!
1989 911 Targa M491
1980 Triumph TR8 (sold)
2006 BMW M3 (Interlagos Blue)
Old 10-03-2010, 08:21 AM
Thanks!
Remove all of the wires from the speedometer,
and send it in as a unit.
Do not take any of the "inners" out.
Send the whole unit.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 10-03-2010, 08:43 AM
