sugarwood's Avatar
CV boots. What is this domed cap for?
I was watching someone do his CV boots on his SC.
He just packed some grease and installed the boot with the greasy end exposed.
He did not have this domed cap in the center of the photo.
What is this cap for? Is it only on some models?
1986 Bosch Icon Wipers coupe.
Old 06-12-2016, 10:32 AM
If you have an'86 Carrera as your post states, you have them on your car! The '85 1/2-'86 911s use this cap over the inboard CV instead of a gasket. Makes things much cleaner when doing any CV work. Came about with the change to 108mm CVs and larger axles.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 06-12-2016, 10:50 AM
Member 911 Anonymous
DRACO A5OG's Avatar
You lucky Suga, mine is a pre 85.5, 85, I use the gasket type a big mess when I need to drop the engine :-(
'85 Carrera Targa
PCA/POC
Old 06-12-2016, 12:21 PM
Information Junky
island911's Avatar
The reason is to keep people from reinstalling a grease-covered CV to the flange covered in grease. --Dry Metal on dry metal Friction, at that interface, helps keep the joint from moving, which helps keep the bolts from backing out.
Old 06-12-2016, 01:16 PM
sugarwood's Avatar
This was actually on a '78SC, not my car. Thanks for clearing that up!
Old 06-12-2016, 02:26 PM
Discseven's Avatar
Originally Posted by draco a5og View Post
you lucky suga, mine is a pre 85.5, 85, i use the gasket type a big mess when i need to drop the engine :-(
+ 1!
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 06-13-2016, 07:19 AM
Dave Colangelo's Avatar
It was my car, this caused some head scratching for us as the caps were not in the pelican kit but were in some of the tutorials on the interwebs. Drove the car down to Philly this morning with no issues, let the summer begin!
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 06-13-2016, 09:08 AM
