Drivers side floor board mounting piece, how to rivet
Hello,
The pieces circled in the attached pic (not my floorboard) were removed from my floorboard to be cleaned up. How do I reinstall them? If I recall, it has been a while, they were attached with rivets. Based on the holes, large rivets. Where can I find the rivets and what tools do I need to install? Note that my floorboard has two holes each side instead of the one each side as shown in the pic.
There is the front 'bracket' and then two pieces on the back to prevent the rivets from pulling thru the wood.
Who, What, When, Where, Why and How.
Old 06-16-2016, 01:44 PM
Discseven's Avatar
Pop rivet gun. Around $12 at local hardware.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 06-16-2016, 03:37 PM
Member 911 Anonymous
DRACO A5OG's Avatar
That will do the trick or get a punch tool and smash the rivets so they will be a bit wider like I recently did to mine :-)
'85 Carrera Targa
PCA/POC
Old 06-16-2016, 10:55 PM
