Oil Level Sender Torque Settings
Anyone know the torque settings for the oil level sender? thanks
Member 911 Anonymous
Are you using rubber or cork gasket?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Bentley stated 18 INCH/lbs. I think this is way off.
Oil Level Sending Unit: How to Service / Repair / Maintain Go to post 2
You just snug it - 6 or 8 nm I think it is. If you compress the cork gasket it will leak.
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
It's a rubber gasket - 1982 911SC
All you need is an even and small compression of the gasket.
If one wanted to get all OCD I'd suggest just trying it at the 18 in/lb number and see how much even that will compress it. The fact you're using a rubber gasket makes it nearly vibration proof so the nuts aren't likely to loosen up-only time and hardening will.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
They were originally cork (mine is '82 SC):
1982 Porsche 911 SC Targa - Sensors - Page 2 Rubber should last longer and be more durable as long as heat is not a factor. |
"heat is not a factor"? ask a track tire with 30 heat cycles about that.
Nevertheless I would expect the rubber to hold up better. Assuming the rubber is good quality-not always the case.
"Assuming the rubber is good quality-not always the case."
Right that's my point. I'm sure Porsche spec'd cork there for a reason. I wouldn't be chucking a random rubber gasket on there. |
