Can't get rear brake light to stick to window
I've got a fantastic brake light all wired up for my '79 Targa SC. Unfortunately, nothing I've tried can make it stick to the window.
I tried super-glue, double-sided 3M tape, and JB weld epoxy. The super-glue never held at all, maybe it doesn't like glass-to-plastic? The tape got warm in the sun and the adhesive released. The epoxy held on until I tried to remove the tape I used to keep it in place while it set. Any ideas?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Doesn't sound like you cleaned very well or didn't let the cleaner dry enough before installing.
Remove whatever is there now, with a flat razor blade. Clean with rubbing alcohol thoroughly. Let air dry 5 minutes before you use any clean cloth to also wipe dry. Use the 3M clear glass/mirror double sided tape. Excellent for this application. I used it to hold a 8' plate mirror onto a custom stainless steel metal frame and could not get it loose.
84 911 03 996tt 09 GT500- for sale! 06 325xi 11 FX4 |
Occasional User
If you are ok to pay the Porsche tax, you could order the adhesive from the dealer part number A 000 043 069 00 adhesive for frame for light
Vince 2015 Boxster S, Black & Black 1989 Carrera Silver Coupe, Silk Grey - sold 2009 Cayman S White, Full Cocoa - sold 1972 911E Silver Coupe, Pepita & Black - sold |
Any 3m doublestick will secure it for years. Installed mine in 2008. Sounds like there's silicon or something on the glass.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
ROW '78 911 Targa
Acetone, then alcohol should get the grunge off.
How about the little tube of adhesive that bonds your rear view mirror "puck" to the windshield. Just takes a tiny drop. All the FLAPS have it. It bonds the mirror like crazy!
Just a thought.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Member 911 Anonymous
When I re-did my tint, I used clear 3M glass tape, worked perfectly.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Counterclockwise?
As the 2 posts above. You need to use the stuff that is designed for this application.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
