Dear Friends
I have this 1976 911s and because I´m very naive /stupid I though that replace the original flag mirror for a old ´73 style was just a matter or remove one and install the other, turns out its not ;-) So, my question is: Where is the correct location for the mirror? If I used the holes for the flag type, the new mirror will became too inclined in the car Also the new mirror is attached from the inside of the door and the location must be precise or will not be able to screw the new mirror from behind. Any input or picture will be helpful Thanks ![]() ![]() ![]() |
You actually need to drill two large holes in the door (inside of door by the door, cowl, fender area) in order to mount that mirror in the correct location. It basically mounts in the upper hole area in that photo. The holes then get covered with rubber hole plugs.
1973 Porsche 911 RS 1981 Porsche 931 Euro-Intercooled-GT 1984 Porsche 911 Euro Carrera widebody 1987 Porsche 924s Rallye Spec Instagram: @soyracer |
search the site - there are some good threads on this subject.
gearhead
![]() Here's the door of my 74. The previous owner, who made it a slant, had updated it to flags. When we restored the body we filled the flag holes and redrilled it for the proper chrome mirror.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
83 911 Production Cab #10
LMFT4U
![]() ![]() ![]() Quote:
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
You are missing the hole to tighten the mirror adjustment Matt
ok, thanks you all
Here is the thread I was thinking of:
Want to replace my sideview mirrors |
OMG, on my 72 the person before decided to move the mirror closer to the rear by half an inch. I have no idea why he decided to do this. Im guessing there was a different mirror of some sort because there is another hole about another 3/4's of an inch even further back toward the rear. So in order to cover all 5 holes I have to mount the mirror which makes almost it impossible to tighten. I have to cut down Allen wrenches to get it tightened. Why am I going on, well because my mirror, or the adjustment part of it, became loose and was flopping around. Took it off yesterday and literally spent over two hours getting it back on. The problem with your situation is that you will have to plug one, or have it welded if you are planning to paint it.
72 911 Although it is done at the moment, it will never be finished. |
I´ll repaint the whole car, so weld the holes ill be no problem
But on the actual holes the new mirror does not fit the position it to VERTICAL and the mirror even on it maximum up adjust still not level So i´m guessing i´ll have to relocate it a little bit up to a more horizontal area of the door |
![]() ![]() Early cars that used the early mirrors, either the round Durant or the rectangular polished, had factory holes on the inside of the door dogleg for access to the bolts that attach the mirror. The picture I posted shows the factory dimples on later cars where these holes were previously drilled. By comparing the locations of the outside holes in Matt's picture and the inside location of the dimples, you can see the old style mirrors were mounted further forward and higher up on the door than the later flag mirrors. Even the well done modification of the base of an early mirror, shown in the link, positions the mirror in a different location than the factory. Notice this very well done mod that covers the original flag mirror holes. Notice the mirror's location relative to the base of the A pillar and you can see that it is further back and lower that a factory early mirror mount. ![]() ![]() Here is the factory location ![]() Since you are going to weld and paint the door, I'd suggest you try every effort to match the factory location for both the inside and outside holes. Someone with an early car could easily measure the location of both holes and post them for you.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 07-04-2016 at 07:38 AM.. |
Have someone make a template for you, using the front curved edge of the door to locate.
looking at replacing the black flag mirrors on my 80SC and do the rectangular early chrome flag mirrors cover the holes left from the removal of the factory SC flag mirrors or is there an oversized gasket or seal that would cover them? anyone been there done that? thanks
1980 911SC Targa 3.6L |
Please look at post 11; that is what needs to be done for a flag mirror replacement if you don't want to do the weld and paint way. The base of the chrome mirrors with standard gasket will not cover...based on other such posts and my direct experience on my 1985 (see post 111 here for my result -> so this is how a backdate project starts...).
So you can interpret what you are seeing here...for best fit of the mirror to cover the most of the holes, I drilled here. The left side mirror is the hardest as you have to drill the two holes through to the inner door panel and due to location one is right up at a crease as you can see. The mirror location on the other door doesn't require this. You can see the continuation of the holes through the inside door surface too. A long drill bit was used.
![]() I made a rectangular back plate to bridge across the holes and beyond. ![]() For the thin ABS parts that I made, I used the rubber gasket as the pattern and extended the outline about 3/16" all around. I then drilled out clearance holes for the two rivet heads you can see above so the ABS part sits flat. My recollection is that if you were to install the mirrors with the bases reversed (might look goofy though), you might get the bases to just about cover all holes. Last edited by SpyderMike; 05-02-2017 at 02:29 PM.. |
@SpyderMike - Did you ever try the later chrome mirrors (75, 912e, etc.)? I've read they have a larger base so I'm curious if they might cover the holes.
Thread Tools | |
Rate This Thread | |
