Question 911 Gauges for a backdate project
Dear Friends,
I´m backdating a 1978 sc into a 1973 and i would like to fit the ´73 gauges on the car
Problem is that the actual car use a electronic Speedometer and the ´73 speed gauge that i have is mechanical
So, how do i solve this problem?
Old 07-11-2016, 05:44 PM
Banned
Talk to NHS speedo or with Palo Alto Speedo, they should be able to help you., cheers, Stef.
Old 07-11-2016, 06:47 PM
cnielsen's Avatar
Yes, they can cosmetically change your gauges to look like the 73 gauges.
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 07-11-2016, 08:20 PM
Cairo94507's Avatar
Palo Alto Speedo did all of my gauges and I converted my cable driven speedo to a later electronic speedo so I could add the extra digit on the odometer to keep the actual mileage accurate. Early cars just went to 99,999. Hartmut did the conversion by adding a VDO converter which changes the gear driven inout to electronic output for the speedo.
'71 914-6 #0372
'17 Macan GTS
Old 07-12-2016, 05:08 AM
