SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
I'm planning on a rebuild. It wont be until December, unless something bad happens sooner or I just can’t wait. SSI exchangers w/ new muffler, 20/21 cams, haven't decided on P&C's yet. Don't know if a c/r increase is worth it on my, so far, 100% streetcar. Waiting for the rebuild book to be done before I decide everything.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 12-28-2002, 05:44 PM
tbitz's Avatar
I'm in progress of doing the CIS-to-EFI project using the megasquirt ECU. Should be complete before spring time.
I'm also in the process of collecting all the pieces for turbocharging. I have the backdated exhaust that will feed a single turbo.
Tony
'78 911SC with BITZRACING EFI conversion kit
Old 12-28-2002, 05:55 PM
juan ruiz's Avatar
650 RWHP By the End of the year
10.76@139-1/4 mile
0-1 mile 193MPH
I Love to Shine Cars
Old 12-28-2002, 06:15 PM
cary's Avatar
Rebuild the engine in my 73 914. Needs a NEW case put around my good parts. Big Hole...........
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 12-28-2002, 06:18 PM
mm86911's Avatar
Still toying with the idea of 3.4 with 10.5:1, twin plug, work heads, extrude hone intake - already have the good exhaust, mass air upgrade, etc. Objective is 300 HP. Then fiberglass rear bumper to loose an extra few pounds to enhance the power increase.
But I really need the final copy of Wayne's Engine book (with color pictures) to complete the spec list!
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
'79 911 SC Widebody PCA, NASA, PBOC - SOLD
2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3
Old 12-28-2002, 06:26 PM
Late next year I intend to start my R'ring project, the motor part is looking like a 2.5 liter shortstroke. Twin Plug, weber carbs SSI Dual in/out muffler. This from a current 2.2T motor. So JE high compression pistons, 2.7 Cylinders, a Mag 7R case normal rebuild stuff.
Robert
Currently Porsche less (but the wife has 2)
iamfoofoo
Guest
Posts: n/a
With some more research I should be deciding soon to either add a turbo or do a 3.6 transplant. I know the costs of a 3.6, starting to look into the turbo route....
If I go the 3.6 route i will have a very nice 3.0 euro with SSI's for sale which has all sorts of new parts including a new and apparently hard to find euro fuel distributor...
If I go the turbo route i think i will have to sell the SSI's and rebuild the 3.0 in preparation for a turbo. The turbo route to me seems more interesting...
I could snap and sell the SC and buy a 993 and start all over!
Old 12-28-2002, 06:30 PM
3.6 conversion in my 2325 lb. 78SC. The front oil cooler in the MA Shaw Yellow Bird valance will go in in the next 2 weeks. I haven't chosen a motor yet, but I've been accumulating the conversion parts and other items to change with the motor out. I am hoping to do a 2 day swap - drive into the garage on Friday night and drive out Monday morning to go to work.
Ryan - you have to go with the 3.2 jugs and pistons as long as you are rebuilding!
Old 12-28-2002, 06:47 PM
Author of "101 Projects"
Wayne 962's Avatar
Okay, time to learn. Tell me (and everyone else) about this MegaSquirt thing? I read the home page the other day, but it wasn't 100% clear? This is an open-source system that someone designed using off-the-shelf components (like the Linux of the EFI world) to replace troublesome fuel injection systems (like CIS?)...
More info please...
-Wayne
Old 12-28-2002, 07:34 PM
I plan to fix some oil leaks. I am going to build SS heatexchangers and install a G50 tranny. Maybe upgrade the turbo to a K27. I hope to have it all done by spring.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 12-28-2002, 07:42 PM
I'm planning on looking for a 2.4 crank for my 2.2 T case, installing E p&c'S and E cams with an MFI setup for my early P. I need all these bits so I'll be posting some WTB posts. I'm armed with the engine book so apsrt from the parts I'm all set
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 12-28-2002, 07:51 PM
Elombard's Avatar
I would like to rebuild, might not be until O4' Mine is a 78sc motor in a 73T body
Like this:
used 9.3 PCs from a newer 3.0, 3.2 or...
have my Cs replated and after market pistons
hotter cams, probably a regrind
have the crank checked
re bush the Con rods
used carbs
aluminum pressure plate.
re curve the distributor if necessary/possible
new oil pump
pressure fed tensioners
heads rebuilt at the place you used with stainless valves
the normal budget rebuild!!
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-28-2002, 08:19 PM
This is an area I’m still very unsure about and I bet Wayne’s book would take care of my ignorance here.
I thought that the SC heads would not seal to Carrera Cylinders. No grove for the sealing ring I believe. Is there a way around this or do I need new heads too? $$$ Ouch!
Also, I have never met anyone that has actually done 20/21 Cams AND 3.2 P&Cs. I’ve met guys that have done one or the other and the guys that have done the Cams have been the happiest w/ it. Actually I’ve only met one guy w/ the short stroke 3.2 and he said he felt like he needed to be at 5000 rpm all the time to stay in the power. Anyone else have experience w/ this?
I would love to talk to someone who has personal experience w/ both mods on their engine.
'81 911SC Targa 3.6
Old 12-28-2002, 09:49 PM
Wayne 962's Avatar
Read my other thread on detonation before you start to mess with stock 3.2 engines...
The 3.2 and SC heads are nearly identical - just the ports, and the size of the intake runner mounts are different. The way they mount to the cylinders is the same...
-Wayne
Old 12-29-2002, 01:35 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
since I am in Germany for a few years, I have decided to concentrate on the heart of the car, engine and suspension. I have decided to go with a 3.6 (993) transplant...this project will start NLT Feb, and the second part of the project will follow into the summer and will include new shocks all the way around with beefed up components where needed.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 12-29-2002, 02:41 AM
Buy them, sell them
Adam's Avatar
While I don't have an engine-project planned, my New Year's Resolution is to build up a 915 with "Airport Gears" or something close and low-ratio for the 2.7 to give it some extra punch.
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 12-29-2002, 03:13 AM
I also have an engine to rebuild, in my Carrera 3.0. I will probably go with 3.2 P&Cs and 964 cams, along with a 930 oil pump, dowel pinning the cases, lightening and balancing the lot. Not before fall, though, as professional commitments will prevent any serious work for 2003.
GeorgeK
Old 12-29-2002, 03:38 AM
Paul_Heery's Avatar
Hey Wayne, if you want to learn about the MegaSquirt all you need to do is read your other forums. Megasquirt - OK, fess up
Old 12-29-2002, 05:05 AM
Senior Member
Doug Zielke's Avatar
I hope most of my "Engine Project" will be finished soon after '03 rolls in.
Then, I intend to drive, drive, drive!
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 12-29-2002, 09:31 AM
