Seeking Ideas/Examples of Clutch Pedal Repairs
My '74 clutch pedal bent. After bending it back, is lasted for a few months but bent again. I have tried to order a new one but they are no longer available. I purchased a used pedal but it seems to have the same issues.
Has anyone welded a piece of steel to their pedal to "brace" it up? I'm looking for ideas before I attempt to weld any additions to mine.
Thanks in advance...
Old 07-06-2016, 10:15 AM
Location: behind the redwood curtain, (humboldt county) california
Binding bushing or Godzilla clutch???
Hey Vern,
What's up??? Is the pedal bushing seized, or did you put in a high effort Pinto clutch??
Did a PO install a clutch stop lower down on the foot boards??? Or is the clutch cable seized in the housing.
My 74 is bone stock and the pedal seems to get the job done easily.
Is there some bad JuJu going on, perhaps a Natzi Dyke Hooker had her dog give you the Evil Eye???
Seen it happen, and it wasn't pretty.
Best of luck,
chris
sorry, no photos
Old 07-06-2016, 07:06 PM
I'd try and figure out why you are bending clutch pedals first. Something down the line is not right. Unless it's an extremely heavy pressure plate, go over the entire clutch system. I'd be concerned that with a reinforced pedal you will most likely begin to stress something else(clutch cable, throwout fork etc). Unrelated to the issue you are having, but my car's PO grenaded the gearbox because of excessive slack in the clutch cable. As I found out later(after going through the gearbox and trying to adjust the clutch)the clutch pedal snapped at the pivot and got re-welded on a wrong angle, causing too much slack in the cable.
In regards to the new pedal being NLA, have you confirmed that with a Porsche dealer? The part number is valid and comes up in both Porsche Classic EPC and online parts retailers for about $50
P/N 91142307700
Old 07-06-2016, 07:51 PM
This started when I installed a new clutch & cable and I pushed the pedal in (from outside the car) and put too much side force onto the pedal and it bent inward (towards the brake). I bent it back into shape but it seems like there has been some metal fatigue and may bend again. It is currently working but I was thinking of adding some bracing since I cannot find a new pedal anywhere on the net.
Pedal cluster is otherwise in great shape and has had all the bushings replaced.
I will check again regarding getting a pedal from Porsche. I've ordered this twice from Pelican and each time I've been told "Porsche only part, from Germany, + 20% and then later get notice that it is not available)/ I really wish they would take the item of the sales list since it is frustrating to go thru the order process and then get turned down.
Old 07-07-2016, 10:42 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Shows us a pic, have you removed it from the car?
'85 Carrera Targa
PCA/POC
Old 07-07-2016, 01:58 PM
I'll take a pick when I get home. Yes, it is currently removed from the car and replaced with a used replacement. However, it looks like the replacement has bent in the past but I cannot confirm that.
Old 07-07-2016, 03:06 PM
ROW '78 911 Targa
timmy2's Avatar
Shows NLA at Sunset Porsche here in Oregon. They are normally very up to date unlike some other on line sites. My go to site when Pelican shows NLA.
91142307705 is still available.... Not so cheap...
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-07-2016, 04:27 PM
Vern you can probably get it from Pelican. It usually comes up unavailable locally then they order it from Porsche Germany and it gets shipped over.
Old 07-07-2016, 06:33 PM
Mine is out of the car...
Hi Vern,
Mine is out of the car and disassembled for a cluster refit. If you need any measurements of an "Unmolested" clutch pedal arm, lemmeno,
:-) Chris
Old 07-07-2016, 07:12 PM
Ridge Restorations
Hi Vern. I have anything you need
All pedal parts from 65'-82.
Let me know if i can help.
None
Old 07-28-2016, 12:46 PM
