Yet another 3.2 Start question
My 3.2 has started to do something very peculiar in the no-start department. I haven't found any references to it searching here, but what happens is I turn the key and absolutely nothing happens. No Crank, no clicks nothing, then I can turn the key back and turn it again and it'll fire right up.
I've replaced the DME relay and no difference occurs, has anyone seen this? thanks!
1971 911T British Racing Green 3.2L 2013 981 Boxster S Aqua Blue/Grey 2014 981 Cayman S Agate Grey/Black enjoyed and passed along: 1990 964 C2, 2007 C4S Cabriolet, 1997 986, 1958 356 A |
My '88 has done the exact same thing about 6 times in the last few months. Intermittent, so haven't been able to track it down. Cleaned the terminals on the starter yesterday & I'll see if that does any good. Would hate to think it's a starter problem. Maybe ignition switch going bad.... who knows
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Member 911 Anonymous
Battery Voltage checks out okay? Have you checked the ground from the gear box to the chassis?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Sounds like ignition switch to me. Unscrew the electrical part of the switch ( no easy task). Put a screwdriver in the slot and turn it (make sure you're in neutral). If it starts consistently check the tab on the mechanical side. sometimes they bend, crack, etc. which will prevent it from turning the electrical part far enough to make contact.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Thanks I'll check those things, as I said it only does it once, then the next time you turn the switch it'll start right up. I replaced the ignition maybe 10 years ago (I remember having to rekey the car) and it's not driven enough for it to really wear out... It's almost like the thing that prevents you from starting it twice is engaged
Try spraying some brakleen in the key slot followed by some spray lube.
