Source for OEM Vacuum Hoses
Hey all - i've scoured the web, host, everywhere and other than porsche $$$$ factory, has anyone found a source for the OEM hoses, cloth covered etc in these sizes? Trying to keep factory look (ON THE CHEAP!!!)
#99923901040 4x9 hose #N0203612 4x1.5 #N0203611 12x2.5 I've been able to local all the other sizes need for the refresh i'm doing during engine drop. Thx! |
Member 911 Anonymous
What are the three hoses for?
Also take a close look at the frunk fuel line hoses to the white evap box, those are leaking now after 30+ years. Ask me how I know.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
i already replaced all the breather hoses in the frunk last year, along with the rubber joint between the filler neck and the tank. i have some extra hose factory cloth wrapped for that area if you need it. |
If just a breather hose for the canister, just use any cloth wrapped 3/8th in hose, it will fit just fine. I am actually using a straight rubber hose as it was easier to thread thru the grommet on the chassis. I will fail Concours for sure :-P
Oh thanks for the offer, I actually replaced those with the proper Cohline for Porsche brand, like the gas station hose lines, very expensive ![]() Good idea on the brake booster line while engine is out, notorious for cracking at the harsh bend to the tunnel.
Do you have a source for the hoses? I'm coming up empty...
Fahren mit dem Wind.
Did you check Belmetric? I have a different sourcing problem, I can't find vacuum hoses with a smooth rubber sheath for the CIS hoses.
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net) Caregiver to: 1983 911 SC Cabriolet - Fahern mit dem Wind. (Moss Green Metallic over Champagne and Brown Leather) |
I just order all the sizes, I know not economical but I figured I will replace them all and if I have left overs just give it to a buddy
Lol. I tend to do same. I buy bulk. |
I wonder if the cloth covering can be removed and the hose will relax to a smooth rubber? Might be the only way to get the hose I need. I'm not a concours fanatic but I like to use original materials if possible. I also think the smooth hose is easier to keep clean in the engine compartment.
Not sure if the covering can easily be removed. I'm not a concourse guy either, but this car is so original i'm trying (hard!) to keep it as original as possible.
But 4x9mm braided can't find! For example... |
Try Midwest Hose. They have that hose on bulk rolls. The home office is here in OKC but they have offices in several states.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Try your local VW dune buggy shop as they usually have it all. (at least out here)
